Toymods » Tech & Conversions » engine conversion into ke30
dave_ke30
sydney, the shire
engine conversion into ke30 Thu, 28 October 2004 05:45 Go to next message
hey im just doin a bit of research into doin an engine conversion into my ke30.... my main concern is with mounting and modifying the mounts to fit either a 4age or 4agze. do the crossmember mounts need to be moved? (ie. cut and weld into new position) and what will be the go for rubber? any other info on this conversion would be great too.thanks
dave.
ke382TG
Re: engine conversion into ke30 Thu, 28 October 2004 06:46 Go to previous message
You could have a chat to ke30turbo on these forums. He has a 4AGTE KE30, similar to what it sounds like you want to do.
Engine mounts will need to be modified in the KE30 for a 4A fitment, it's really not that much trouble though.
The engine mounting modification setup can be different depending on whether you go with 4AGZE or 4AG/4AGTE as the supercharger sits in the way of where you can bolt one of the engine mounts to the block on the drivers side i.e. in supercharged form the engine mount has to be mounted further rearward (which is further away from the original mount on the KE30 crossmember).
With the supercharger gone (4AG or 4AGTE) the engine mount on the drivers side can be mounted in the more forward position and will come much closer to the orignial crossmember mount, hence requiring a little less work to modify and will usually look neater.
So, yes there is a need for cutting and welding, get new engine mount rubbers from a spare parts shop. Don't waste your time with old ones, new ones are cheap and they don't have to be specifically for a 4A either.
Edit: oh yeah, I might be able to get some photos of my brothers 4AGTE in a KE38 (same engine mount mods you will require) next week if you still need them by then. I am away from tomorrow so send me a PM on Monday or Tuesday to remind me when I get back.
[Updated on: Thu, 28 October 2004 06:52]
Previous Topic:car running like shit
Next Topic:Need help!! where should i go
Current Time: Sat Nov 21 03:01:50 UTC 2026
Total time taken to generate the page: 0.0039141178131104 seconds
