Toymods » Tech & Conversions » TA22 diff question
scano
TA22 diff question Thu, 28 October 2004 09:57 Go to next message
mates got a 2T with hurricane headers, 2" exhaust, 32/36 weber, and 5spd behind it, i wanna lock up the diff in it but i need suggestions about with to do wether to put a hilux centre with lsd or TIG it up and what are the diff gears behind a manual? any diff gears better to put in the old girl???, also putting a cam in the 2T what is the best suggestion of the best cam without upgrading springs etc.. and how hard to put it in. cheers
Jonny2TG
Tasmania
Re: TA22 diff question Thu, 28 October 2004 12:25 Go to previous messageGo to next message
The 2T engine with headers will not be too much power for the original diff. But if you weld it up, it won't last forever. You will eventualy snap an axle, or break the weld if its not very good. But don't let me put you off, driving with a locked diff is great. It will last for a bit.
A good thing to do is buy a LSD, to suit a early Jap AE86. The center will be about $650 from a importer. Its alot of money, but worth it because you get the same sort of thing as having a locker, but not likely to snap axles, or disturb people in the car park.
For the cam, I would go as wild as they make. You only live once.
Hilux diff is strong, but only realy needed for turbo power.
fade-e
Re: TA22 diff question Thu, 28 October 2004 16:28 Go to previous messageGo to next message
with the AE86 centre make sure you got the same diff as an '86. i believe the '22s came out in diff series, D and T. the '86s use T series and you will end up with a T series LSD centre.
for memory, every celica iv owned has been a D series
greenta22
Dandenong Ranges, VIC
Re: TA22 diff question Fri, 29 October 2004 12:55 Go to previous messageGo to next message
so you dont neccesarily get a T series diff with a T series gearbox and a T series motor? thats what i assumed...
ive got a 75 TA22, how can i tell what diff it is?
fade-e
Re: TA22 diff question Fri, 29 October 2004 13:23 Go to previous message
on the compliance plate, where it says AXLE, it will either start with a T or a D
Previous Topic:What's the Thermostat setup in the 4AGTE article???
Next Topic:delete me
Current Time: Wed Nov 4 08:01:58 UTC 2026
Total time taken to generate the page: 0.38673615455627 seconds
