Toymods » Tech & Conversions » AE86 intercooler
ae95
AE86 intercooler Thu, 28 October 2004 11:17 Go to next message
Anyone running a big intercooler? if so i'd like to know how you made it fit. im talking about a 600x300x76mm cooler. i had a quick look at my car and dont see a way to fit a big one in there
drift86levin
brisvegas
Re: AE86 intercooler Thu, 28 October 2004 21:29 Go to previous messageGo to next message
mine is only 400x240x60 but none the less here is howmine is fitted..just one tab/bolt on the top, and the silicon holds it in the position it looks real neat considering my mate done it without having a front bar to position it off!! fits beautiful!
http://cruisingbrisbane.com/forum/index.php?s=072d 3daa7cad4cbe9b6f16073bfc4dfe&showtopic=3413
sorry..my home pc wouldn't let me upload pics Confused so there is my car on another forum
gabe
Re: AE86 intercooler Fri, 29 October 2004 01:14 Go to previous messageGo to next message
I am running a 500x297x73, and in my opinion, it's the largest possible without cutting stuff.
You're welcome to come take a look if you want, and I can take a look at your RWD 4AGE while your here....
Gabe
ae95
Re: AE86 intercooler Fri, 29 October 2004 05:17 Go to previous messageGo to next message
thanks guys
ill be test fitting a gtr cooler today. doesnt look like it will fit
Ribbo
Northern Beaches
Re: AE86 intercooler Fri, 29 October 2004 09:28 Go to previous messageGo to next message
im running Core Size of: 450x300x76, you could fit a bit bigger, but gtr cooler would require some cutting... Ill probably be getting some pics of it tomorrow, it fits real nice
ae95
Re: AE86 intercooler Fri, 29 October 2004 09:29 Go to previous messageGo to next message
ok
sized up the gtr cooler might fit with a few mods.
where do you guys run the coolerpipes? do you cut the metal under the headlights and run it through there?
Ribbo
Northern Beaches
Re: AE86 intercooler Fri, 29 October 2004 09:36 Go to previous messageGo to next message
my cooler runs with pipes at top, 3inch silicon bends just fit under the headlights around and up
drift86levin
brisvegas
Re: AE86 intercooler Fri, 29 October 2004 10:43 Go to previous messageGo to next message
i cut under the drivers side light..but i used the top of the chassie rail on the passenger side..i had to make it a little larger
Re: AE86 intercooler Fri, 29 October 2004 11:17 Go to previous messageGo to next message
I can't remember the exact size, but I got one made up as big as I could stuff in there some time ago. I'll try and remember to measure it tomorrow, and I might even be selling it off soon Very Happy
Sam_Q
S.E suberbs, Vic
Re: AE86 intercooler Sat, 30 October 2004 02:17 Go to previous messageGo to next message
a 600mm wide intercooler wont fit. I guess its theroeticly possible but you will need to re-engeneer the radiator support and also make custom headlight mounts that only hold them from one side. 450mm wide is the max recomended size
optionUP
Perth, WA
Re: AE86 intercooler Sat, 30 October 2004 10:11 Go to previous messageGo to next message
You talking core width or total width?
Also, should the question be along the lines of: "what's the biggest intercooler I need to run to get the power I want", not "what's he biggest that will fit" ?
OK, if you're trying to get all the power you can, then a big intercooler is maybe what you want, but if you just want something under/around 200hp, then you could probably get away with something relatively small.
My sprinter uses a stock intercoolr from a R33 Skyline (core size couldn't be bigger than 300mm wide x 300mm high) and my car makes 145 rwhp on 15psi boost.
Of course, I wonder if it should be making MORE than this, and whether the intercooler's to blame... Rolling Eyes
ae95
Re: AE86 intercooler Sun, 31 October 2004 04:16 Go to previous messageGo to next message
600mm is the core width. with the end tanks its about 1m wide. i want to use this cooler because i've already bought it and it has nice endtanks compared to the hybrid style ones you see floating around everywhere. I'm aiming for about 250rwhp
takai
Re: AE86 intercooler Sun, 31 October 2004 04:32 Go to previous message
1m wide, heck. the entire front of the 86 isnt much more than that. 1430mm i think, Thats not much more in the whole scheme of things. Good luck.
Previous Topic:Unknow injector
Next Topic:Wheel Sizes
Current Time: Fri Oct 30 18:19:05 UTC 2026
Total time taken to generate the page: 0.0068950653076172 seconds
