Toymods » Tech & Conversions » Downshift > *crunch/grate* :(
Spanktown
Inside a giant turbo (syd...
Downshift > *crunch/grate* :( Thu, 28 October 2004 12:19 Go to next message
So, after all the crap ive been through with my gearbox, what causes a crunch on down shifting. Its 4th > 3rd, im presuming synchro except if i double clutch on the way down it still grates... any ideas?
TA-022
Glenmore Park, NSW
Re: Downshift > *crunch/grate* :( Fri, 29 October 2004 09:42 Go to previous messageGo to next message
dont know a heap on boxes but from what ive learnt most crunches are either a result of damaged/stuffed syncros or pssibly selector forks.
my t50 is the same... a hard click into 2nd no matter how much clutch, warm / cold it is / or even if i double clutch.....ill sort it out one day.
Hope this helps.
Nathan
Spanktown
Re: Downshift > *crunch/grate* :( Fri, 29 October 2004 11:34 Go to previous messageGo to next message
yeah im pretty sure its the synchro, it does it on upshift as well... Im going to try Redline superlight shockproof gear oil before i go and fork out 800 on it.
shinybluesteel
melbourne
Re: Downshift > *crunch/grate* :( Fri, 29 October 2004 11:48 Go to previous messageGo to next message
if that stuff is expensive, jut use ATF, as that is probably what it is anyway
mk1sc
Re: Downshift > *crunch/grate* :( Fri, 29 October 2004 12:18 Go to previous messageGo to next message
what do you mean by grates?
i used to have 4th to 3rd and 3rd to 4th crunches. but im definately sure either replacing my leaky cluthc slave cylinder or adjusting the freeplay rod on the clutch pedal had solved it as i havent had any crunch in a while.
but i still get bit of metallic grinding through gear changes somethimes especially when cold in morning, its little sticky aswell. took it for a fang tonight and was heaps good even though my clutch still slipping bad. slowing down through roundabout and bends i was doing 4th to 3rd at bout 100-90kmh and it felt really smooth
i be changing my gear oil to GL-5 soon, as i read somewhere its what recoomended for the e51 box. probably sticking to duragear again as its cheap and synthentic, cant afford syntrax and redline, we looking at over $100 alone for the oil
Spanktown
Re: Downshift > *crunch/grate* :( Fri, 29 October 2004 13:03 Go to previous messageGo to next message
well i dont think what everyone calls a crunch, a crunch.. its like the gear going up agaist a piece of metal, like grating.... i suppose it could be called a crunch. you can feel it through the stick as well. Ill have to have a look at free play tommorow as well.
the redline is $119 for 4 litres.
levin_boi
melb
Re: Downshift > *crunch/grate* :( Fri, 29 October 2004 13:16 Go to previous messageGo to next message
sorry man i wouldnt have a clue about your crunchy nut cornflakes. i'm just wandering does any1 know what the best suited gbox oil is for a sprinta t50?
thanx
sab
RAV-GT4
Toymods member
Rydalmere, NSW
Re: Downshift > *crunch/grate* :( Fri, 29 October 2004 15:37 Go to previous messageGo to next message
Spanktown wrote on Fri, 29 October 2004 23:03
Is yours a hydraulic clutch or a cable? Also if Redline is that much, go to Supercheap and 5L of Syntrax for the price equivalent of Redline's 4L. Shocked
river
Land of Oz
Re: Downshift > *crunch/grate* :( Fri, 29 October 2004 22:18 Go to previous message
My gearbox sometimes crunches going down from 4th to 3rd. Going up is fine and all other gears are fine. I thought it was the synchro (or, in the case of my box it's a band). It doesn't do it at slower speeds or if I down change slow. What interests me in this topic is the mention of clutch adjustment to fix the problem. Is this possible? A poorly adjusted clutch could fix the problem?
That'd be great 'cos a gearbox rebuild would cost me many hundreds - assuming the bits are available, which they're not. But a clutch jobbie would be cheaper and the parts are available. Oh, and I'll throw in some of that Syntrax or Red Oil stuff too.
seeyuzz
river
Previous Topic:3tgte tps switch wires
Next Topic:kp61 clutch cable to hydro need help!!!!!!!!!!!
Current Time: Sun Nov 1 16:23:14 UTC 2026
Total time taken to generate the page: 0.032531023025513 seconds
