Toymods » Tech & Conversions » need help on torque settings for 4agze!!
Sprinter-Saurus
need help on torque settings for 4agze!! Sat, 30 October 2004 02:04 Go to next message
hey all, im putting my motor back together for the Sprinter, its out of an 1989 MR2, 1.6 supercharged, ive had all the heads done and shit and the motor is in pieces, so i need all the torque settings for the motor.
rod bolts, head bolts, main bolts, etc., all the important tightning that needs to be done.
if anyone has the settings or knows where to get 'em, youre help would be much appreciated.
cheers, Daniel. Smile
ChuckLandwehr
Re: need help on torque settings for 4agze!! Sun, 31 October 2004 05:29 Go to previous messageGo to next message
Hi Daniel, I have the Toyota "A" series overhaul manual here, the torque figures are calculated on bolt/nut sizes, so should be fairly accurate for GZE.
Main Bearings; 41 to 47 ft-lbs. or 54 to 64N.m
Tension centre cap first, then adjacent ones and finally end caps
Rod bearings; 34 to 39 ft-lbs. or 46 to 52N.m
Flywheel: 55 to 61 ft-lbs. or 74 to 83N.m
Head bolt tension and tightening pattern will be on your head gasket packaging.
I would suggest you find a copy of the GZE manual, as there are heaps of other things which need to be checked/measured/ torqued. You have gone to the expense of all the machining work, it would be a pity to blow it all for the sake of a few pages of information.
regards Chuck.
EVOSTi
cambo
      no
Re: need help on torque settings for 4agze!! Sun, 31 October 2004 10:15 Go to previous messageGo to next message
ill bring my AW11 GZE workshop manual to work tomoz, come pick it up.
Skein
Re: need help on torque settings for 4agze!! Sun, 31 October 2004 10:21 Go to previous messageGo to next message
high five to another Daniel with a 4AGZE Laughing
EVOSTi
cambo
      no
Re: need help on torque settings for 4agze!! Sun, 31 October 2004 11:15 Go to previous message
he's dropped the Z in favour of a T.
Previous Topic:What's this in the AE86 engine bay???
Next Topic:installing external wastegate
Current Time: Sat Nov 21 12:30:20 UTC 2026
Total time taken to generate the page: 0.0057270526885986 seconds
