Toymods » Tech & Conversions » 3sgte Gen 3 fuel rail on a Gen 2 motor
Classique71
Colac, Victoria
3sgte Gen 3 fuel rail on a Gen 2 motor Sat, 30 October 2004 02:42 Go to next message
Just need some clarification guys
Will a gen3 fuel rail work with a gen2 3sgte ( 540CC injectors as you know as apposed to 440 )
If not - will the gen3 injectors " plug in " the gen2 rail
Ive heard conflicting views on this so i thojght i better ask before making a purchase
gabe
Re: 3sgte Gen 3 fuel rail on a Gen 2 motor Sat, 30 October 2004 09:26 Go to previous messageGo to next message
Classique71 wrote on Sat, 30 October 2004 10:42
The gen 3 rail WILL NOT fit a gen 2.
However....
Gen 3 injectors WILL fit a gen 2 rail.
I know they do because I have done it!
Gabe
Classique71
Colac, Victoria
Re: 3sgte Gen 3 fuel rail on a Gen 2 motor Sat, 30 October 2004 12:15 Go to previous messageGo to next message
Thats exactly the info i needed gabe - Cheers mate Very Happy -
ill see about this purchase then
PS: the st205 cams are working lurvly - though next round of tuning will show their potential in the Gen2 head with shim unders Smile
JustenGT4
Re: 3sgte Gen 3 fuel rail on a Gen 2 motor Mon, 01 November 2004 01:57 Go to previous messageGo to next message
Yup Gabe is spot on the money.
The GEN 3 rail is a much higher flowing unit though which a much larger bore so it's a damn shame it's not a direct swap.
Classique71
Colac, Victoria
Re: 3sgte Gen 3 fuel rail on a Gen 2 motor Mon, 01 November 2004 06:55 Go to previous messageGo to next message
could you hone/bore out the gen2 rail ?
gabe
Re: 3sgte Gen 3 fuel rail on a Gen 2 motor Mon, 01 November 2004 08:16 Go to previous messageGo to next message
Classique71 wrote on Mon, 01 November 2004 14:55
I also thought about doing this, but there is too much work involved for my liking (also there isn't much meat to take away if you know what I mean), it can be done though.
In the end I decided to make a new rail which houses more common/cheaper top feed injectors.
If you end up keeping the stock rail, I have some custom bits you might be interested in. PM me if you're at all interested, I can supply pictures for you too.
JustenGT4
Re: 3sgte Gen 3 fuel rail on a Gen 2 motor Mon, 01 November 2004 20:54 Go to previous messageGo to next message
You can and they do but i don't recommend it.
A better approach is to dual feed the rail and use the cold start port as the return.
TRD_Celica
Hobart
Re: 3sgte Gen 3 fuel rail on a Gen 2 motor Mon, 01 November 2004 22:39 Go to previous message
In a 1990 SW20 what series 3S does that have in it ?
Previous Topic:18R-GEU Dizzy question with HEI kit
Next Topic:AE86 T series rear sway bar
Current Time: Thu Nov 19 08:06:19 UTC 2026
Total time taken to generate the page: 0.057440996170044 seconds
