Toymods » Tech & Conversions » ra65 tank into sa63 coupe
rokusan
western queensland
icon5.gif  ra65 tank into sa63 coupe Sat, 30 October 2004 05:42 Go to next message
does a ra65 and sa63 take the same tank? even between coupe and hatch models? i have done a search on old posts and found the ra65 efi tanks are baffled, would the efi pump be suitable to feed a surge tank with a bosch m'sport pump? i'm using a skyline one at the mo' but i'd like the baffles and internal pump, it,s for a drift/sprint car with 350ps.
how much does an ra65 tank and pump etc. usually go for?
thanks, love the wealth of info on this site Cool
stark
Re: ra65 tank into sa63 coupe Sat, 30 October 2004 09:07 Go to previous messageGo to next message
As far as I know the fuel pump in the RA65 is the same as the MA61 Supra... Which would mewan that you can get the Walbro 255lph replacement... The fuel tank is baffled and I doubt you would need a surge tank..
The part number on the Walbro pump is GSS341 and will be fine upto 450HP
rokusan
western queensland
Re: ra65 tank into sa63 coupe Sat, 30 October 2004 13:10 Go to previous messageGo to next message
ok cool, but i need to know if the tanks are the same? i already have an external bosch pump and yes i do need a surge tank Smile
stark
Re: ra65 tank into sa63 coupe Sun, 31 October 2004 04:49 Go to previous messageGo to next message
rokusan wrote on Sat, 30 October 2004 23:10
Ok well in terms of the tank all the XA6X series celicas came with two different fuel tanks from memory... Basically you have to check if your RA65 and SA63 have the same suspension setup, as the solid axle rear end and the IRS rear end had different tanks... If they are both IRS or both solid axle then im pretty sure the tank is the same. Just look in the boot/hatch... If you can see shock towers at the back its an IRS otherwise its the solid axle
Mookie
Tassie
Re: ra65 tank into sa63 coupe Sun, 31 October 2004 05:22 Go to previous messageGo to next message
I have a SA63 and my mate has a RA65.
from what i can see the tanks are both the same and i'm told they are the same size.
mind u we both have the liftback models.
My other mates has the sedan model and the tank appears to be longer and flater.
Don't take it as gospel tho. i can measure it when he comes round next if u like
rokusan
western queensland
Re: ra65 tank into sa63 coupe Sun, 31 October 2004 08:37 Go to previous messageGo to next message
thanks, i had a feeling the coupes and liftbacks were slightly different? i definatly have IRS, didn't know you could get a solid rear axle in these, oh well learn somthing new Cool
BTW has anyone done anything cool with the stock IRS?
Mookie
Tassie
Re: ra65 tank into sa63 coupe Sun, 31 October 2004 09:03 Go to previous messageGo to next message
I'm pretty sure it's only the RA60 that has a solid axle.
I haven't done much with my suspension at all i lowered it a little so the car sits level, Next up will be stiffer springs or at least dual rate springs.
I don't know if u have noticed but when u try to launch hard off the line the inside of the tread is the only part of the tyre in contact with the ground.
so u will end up with tyres like rollerblade wheels.
I'll be getting a RA65 tanks as the 1G i plan on putting in has EFI.
so it will be interesting to see how much they will sting me for a tank.What do u have a sedan or hatch ?
rokusan
western queensland
Re: ra65 tank into sa63 coupe Sun, 31 October 2004 09:38 Go to previous messageGo to next message
sedan boot back coupe thingo Laughing o
was thinking of using another irs in it? wataya rekon? am i crazy Very Happy i'll have a good go at it, anyway how do i post photo's on this?
Mookie
Tassie
Re: ra65 tank into sa63 coupe Sun, 31 October 2004 12:10 Go to previous messageGo to next message
Sorry i didn't quite understand what u said, What do u mean use another IRS ?I dunno if u can post pics on this part of toymods. but don't quote me on that u might have to use imagebucket or something.
We say to my mate with the coupe that somebody fat has sat on his boot and that's y it's shaped like that.
I tell you tho the back end of those are so strong i ran into the back of him (not totatly my fault) at like 50 kms and all it did was bend the tip of his exahust pipe.
I'd love to see somebody do something cool with these cars.
Down here we need to keep them looking pretty stock or we get put on "the list" the cops have .
rokusan
western queensland
Re: ra65 tank into sa63 coupe Thu, 06 January 2005 08:04 Go to previous messageGo to next message
well i have bits of skyline lying around so i'm going to try and put that in there. Mad
also i've found an MA61 tank forsale, i hope that fits Confused
Re: ra65 tank into sa63 coupe Thu, 06 January 2005 09:16 Go to previous message
Well an RA65 tank went straight into Nark's RA60, so I don't think there will be any issues with swapping one between the IRS versions of the chassis.
Previous Topic:im back, injector probs??
Next Topic:Air con compressor replacement
Current Time: Fri Nov 20 14:32:20 UTC 2026
Total time taken to generate the page: 0.046290874481201 seconds
