Toymods » Tech & Conversions » Removing Bump Strips
icon5.gif  Removing Bump Strips Fri, 04 October 2002 09:20 Go to next message
I'm removing the bump strips on my car at the moment. What is the best way to fill the holes left? Should I just bog over them and make sure they are done properly?
Rolla Boy
Club Member
Sydney, NSW
Re: Removing Bump Strips Fri, 04 October 2002 12:47 Go to previous messageGo to next message
Personally I wouldn't do it if there was holes underneath...
But I think that ppl just bog the holes up and yes, make sure they are done properly as you said...
humble
Brisbane, QLD
Re: Removing Bump Strips Fri, 04 October 2002 12:55 Go to previous messageGo to next message
Dude, whatever you do, don't bog.
To my knowledge, the compound bog is made of has tiny molecular lattice level spaces that can encapsulate water molecules. So basically, bog absorbs water and would lead to rust around the bog (that is why bog is never a solution to rust). What I would recomend is some fibreglass resin or something similar that doesn't absorb water.
Alainve
Newcastle NSW
Re: Removing Bump Strips Fri, 04 October 2002 23:38 Go to previous messageGo to next message
BOG IS BAD!!!! Shocked for that purpose anyway. if you can get to the back of the panel easily a small sheet of fiberglass is the go, if access is a bit harder (but you can still get a finger to the back of the hole) then use a fiberglass reinforced body filler. if you cannot access the back of the hole at all then it becomes tricky, you need a small piece of mesh or anything you can physically fit into the hole thats not absorbent that you can also attach a bit of fine wire to. Then jam it thru the hole squeeeze some fibreglass body filler in and pull the wire to squish the filler out at the back to make it strong!.
its time consuming but when done properly a loud stereo cant budge it
Youngy
Eskilstuna, Sweden
Re: Removing Bump Strips Fri, 04 October 2002 23:40 Go to previous messageGo to next message
Or do what the hot rod boys would do and go for a file finish by welding the holes up, but the fibreglass idea is a good one. A friend of mine has done a fair amount of his L300 van in fibreglass..........Smile
wizzfizz2097
Re: Removing Bump Strips Sat, 05 October 2002 00:48 Go to previous messageGo to next message
my strips are glued on with some tuff rubber crap, i can get the strips off but it leaves this rubber behind. any ideas about getting if off without damaging the paint if possible? ive tried peeling, scraping... i was thinking about someting chemical that will do the job
CrAiGzEE
south of the big smoke
Re: Removing Bump Strips Sat, 05 October 2002 07:25 Go to previous messageGo to next message
just put a little pop rivet in there! hehehe
if sure the rive look will increase the looks of ya car
rollaboy
Coffs
Re: Removing Bump Strips Sat, 05 October 2002 10:05 Go to previous messageGo to next message
SPEED HOLES Smile
jase
Re: Removing Bump Strips Sat, 05 October 2002 11:39 Go to previous messageGo to next message
When I had my RA60 I had all the holes welded up on both sides.
14 a side if I remember correctly......
Re: Removing Bump Strips Sat, 05 October 2002 12:52 Go to previous messageGo to next message
Thanks for all the suggestions guys. I think I will follow up the ones with the fibreglass and the welding, check how hard they will be each. Will steer clear of the bog. Might just have to pass on the speed holes option though Very Happy
jazae86
Re: Removing Bump Strips Sat, 05 October 2002 14:57 Go to previous messageGo to next message
When removing sticky shit: never look past wax and polish remover: it has been extreemly helpful in stripping my car. I took the left over rubber sealant off the chassis around the rear 1/4 glass.
I'm pretty sure I used it to remove the glue when I took the bump strips of the 86 (only glued on Smile ). and the pin stripes (along with a scalple Evil or Very Mad ) tho you will need to polish the spot again:
AND
as soon as you rub the wax and polish remover on, you need to rub it off. YOU don't want to leave any residue. This is VERY important.
Note: cause I was painting my doors, I cannot tell you if there were any long term effects. I'm sure someone else will know.
or you could " find a spot behind a bumper and check..."
Jaz
And I second SPEED HOLES makes you go faster, trust Homer Simpson Very Happy less wieght after all
EVOSTi
cambo
      no
Re: Removing Bump Strips Mon, 07 October 2002 11:53 Go to previous messageGo to next message
i asked about removing stickers not long ago, glad you had luck with the wax and grease remover but NOTHING gets off my sprinters pinstripes ive tried a fair bit. only thing is hard bit of plastic and scratch it off but theres SO MUCH pinstripe dagnammit.
Hunty
Re: Removing Bump Strips Mon, 07 October 2002 12:11 Go to previous messageGo to next message
I pulled the bump strips off my 82 and yeh there was hell glue crap left i used turps a hair dryer and a plastic dish washing scourer in this method : dab on turps, heat and rub with plastic scourer, took about 2 hours to do the whole car.
jazae86
Re: Removing Bump Strips Mon, 07 October 2002 12:15 Go to previous message
The worst news of all is that after you go to the trouble of removing the pin stripes and/or pumbstrips, because they have been on the car for so long, you will have a 'un-faded' section where the stripes use to be.
This mainly affects non-prime colour cars, and your car may have been luckier than others.
The more I think about it, I used a scalple, wax and polish remover before sanding the panel. So maybe wax and polish remover was not as good as I thought Smile
Jaz
Previous Topic:JZA70 cooling system pressure
Next Topic:Real Power Figures 1JZ-GTE?
Current Time: Fri Nov 20 12:42:45 UTC 2026
Total time taken to generate the page: 0.0070350170135498 seconds
