Toymods » Tech & Conversions » GZ20 Soarer yellow plug 26 Pin ECU??? WTF
BLK1GGTE
South Eastern Subs
icon5.gif  GZ20 Soarer yellow plug 26 Pin ECU??? WTF Sun, 31 October 2004 07:41 Go to next message
Hi am curious what versions did the GZ20 soarer come out with apart from gen 2. I am buying a HKS F-CON and it states its for a gz20 1ggte engine. I just want to make sure its for a gen2 ecu?? Also my Gen 2 ecu has yellow plugs but 26 Pin is this normal for a 88 GZ20 soarer. Will this be a problem?? Anyone can shed some light on this
BLK1GGTE
South Eastern Subs
Re: GZ20 Soarer yellow plug 26 Pin ECU??? WTF Mon, 01 November 2004 01:06 Go to previous messageGo to next message
No one can clear this up for me or...nobody has came accross a 1ggte with 26pin but yellow plugs..
Anyone here ever used a HKS PFC-FCON??
Re: GZ20 Soarer yellow plug 26 Pin ECU??? WTF Mon, 01 November 2004 01:09 Go to previous messageGo to next message
I'd be going off the pins as opposed to the colour, Toyota changed small things like that on the whim of the engineer at the time. The number of pins would indicate it's a Gen3 ECU though.
BLK1GGTE
South Eastern Subs
Re: GZ20 Soarer yellow plug 26 Pin ECU??? WTF Mon, 01 November 2004 01:38 Go to previous messageGo to next message
Thats what i thought as well cause it has gen 3 turbos but the actuators only run 9psi...Weird things toyota does Confused
BLK1GGTE
South Eastern Subs
Re: GZ20 Soarer yellow plug 26 Pin ECU??? WTF Mon, 01 November 2004 03:01 Go to previous messageGo to next message
Ok had a look at the ECU and it has 26pin 16pin 22pin/yellow plugs.
the Part number is 89661-24140
If anyone has the same ECU part number can they please tell me and what generation of 1g it came off..
ChuckLandwehr
Re: GZ20 Soarer yellow plug 26 Pin ECU??? WTF Mon, 01 November 2004 06:31 Go to previous messageGo to next message
Hi man, just checked a GenII Auto 1G-GTE ECU. My numbers match yours. And yep I pulled it from my halfcut, which was a 1989 GZ20 Soarer.
regards Chuck.
[Updated on: Mon, 01 November 2004 06:33]
BLK1GGTE
South Eastern Subs
Re: GZ20 Soarer yellow plug 26 Pin ECU??? WTF Mon, 01 November 2004 06:37 Go to previous messageGo to next message
How many pins on the plug biggest plug 24 or 26..It will say it on the sticker near the part number..Just curious
BLK1GGTE
South Eastern Subs
Re: GZ20 Soarer yellow plug 26 Pin ECU??? WTF Mon, 01 November 2004 06:38 Go to previous messageGo to next message
Wasn't anything past 1988 a gen 3 engine??
BLK1GGTE
South Eastern Subs
Re: GZ20 Soarer yellow plug 26 Pin ECU??? WTF Mon, 01 November 2004 08:45 Go to previous messageGo to next message
C'mon all you gen 3 1GGTE owners..a little help..what are your part numbers on your ECU's..
Thanks...
ChuckLandwehr
Re: GZ20 Soarer yellow plug 26 Pin ECU??? WTF Tue, 02 November 2004 06:29 Go to previous messageGo to next message
Same configuration as what you have. 26 - 16 - 22. If it has the same part no, it must be identical!
I also have a 3rd generation 1G-GTE ECU from a GA-70 Supra Manual, it has 24 pins.
regards Chuck.
BLK1GGTE
South Eastern Subs
Re: GZ20 Soarer yellow plug 26 Pin ECU??? WTF Tue, 02 November 2004 09:05 Go to previous messageGo to next message
Hey thanks for the info Chuck... but do you get it at all.. What da hell is going on with Toyota.. I mean a 26 pin Gen 2 ECU and a 24 pin Gen 3 ECU what gives..and does anybody know what those two extra pins are for....???
Do you think I could just plug in a Gen 3 ECU (26 pin) in my Soarer as I heard they have more aggressive tuning..??
Anybody knows..?? Would be helpful if I could get some opinions.
BLK1GGTE
South Eastern Subs
Re: GZ20 Soarer yellow plug 26 Pin ECU??? WTF Thu, 04 November 2004 18:19 Go to previous message
Look as far as I know my ECU is a Gen 2 how come i fouund this out ...1988 early 1989 didn't Gen 2 1GGTE stop …But the thing is I found this on e-bay:
This is a 1990 ECU out of Auto Supra with the same pins and same numbers as ours apart from the 2 instead of the tree on the last digit
_I guess its anybodies guess
Supra GA70 1G-GTEU 2000GT ECU CPU OEM JDM
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?Vi ewItem&rd=1&item=2459703928&category=3 3596&sspagename=WD1V
u more Smile
By the way check out the 7MGGTE grey plug ECU (same as Gen 3 set-up) with the same numbers of pins as a Gen 3 ECU…so I guess its anybodies guess until I get some Gen 3 ECU Numbers
C'mon 1GGTE Gen3 Owners!!!
Supra MA70 7M-GTE Stock Computer ECU CPU OEM JDM
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?Vi ewItem&rd=1&item=7926877801&category=3 3596&sspagename=WD1V
Previous Topic:1GGTE - how much boost?
Next Topic:MR2 SW20 BOV
Current Time: Sat Nov 21 04:38:39 UTC 2026
Total time taken to generate the page: 0.0049540996551514 seconds
