Toymods » Tech & Conversions » help!!!!!!!!
PAULIO
help!!!!!!!! Sun, 31 October 2004 12:51 Go to next message
im having trouble with my engine atm and i was wondering if anyone could help me. i realise it might be obvious but im not seeing it. My car at two thousand revs (if i hold it there) drops about 200 revs and then goes back up and drops and so forth. Im also have problems with it hesitating when i plant it. This made me think it was my carbi but any help would be appreciated . BTW Its a 4afc (carbi)
Confused ANY IDEAS???
Thanx
Re: help!!!!!!!! Sun, 31 October 2004 13:07 Go to previous messageGo to next message
have you checked your sparks? the revs dropping like that could be as simple as a misfire caused by dirty sparks or a bridge somewhere in the leads.
this would also explain the hesitation in accelerating.
Always best to eliminate the simple things first Smile
PAULIO
Re: help!!!!!!!! Sun, 31 October 2004 13:21 Go to previous messageGo to next message
yea i just had problems with the seals aorund the spark leads on the rocker cover and oil leaked into the spark plug. also the lead snapped Shocked so the leads are new as is the plugs and seals. i also put a carby kit through it not long ago and the problems started a liitle bit after that so i wonder if i maybe did it
Re: help!!!!!!!! Sun, 31 October 2004 13:25 Go to previous messageGo to next message
all the vac lines reconnected properly?
no leaks?
PAULIO
Re: help!!!!!!!! Sun, 31 October 2004 13:44 Go to previous message
yea as far as i can tell they are, i made a point to check them ... could it be my timing??? i dont understand why it would be doing it
Previous Topic:Supra JZA70 Vs. MA70 Discs & Calipers
Next Topic:What Injectors to use ?
Current Time: Thu Oct 22 16:51:05 UTC 2026
Total time taken to generate the page: 0.10511612892151 seconds
