Toymods » Tech & Conversions » AW 11 guys, brake pad suggestions
Benno
NSW Australia
icon5.gif  AW 11 guys, brake pad suggestions Mon, 01 November 2004 00:10 Go to next message
I'd really appreciate any suggestions for a set of nice bitey pads for my SC. I have a master cylinder brace fitted but the brakes are still pretty dead as far as initial bite is concerned. If you can also point me in the direction of a Sydney based supplier I'd be grateful. Thx!
Joshstix
Toymods Vice President
Re: AW 11 guys, brake pad suggestions Mon, 01 November 2004 01:07 Go to previous messageGo to next message
The EBC green stuffs have the highest initial coefficient of friction of any pad I've seen data on. They work really nice in an AW11 except there can be a bit more of a tendency for the front to lock up.
Benno
NSW Australia
Re: AW 11 guys, brake pad suggestions Mon, 01 November 2004 01:21 Go to previous messageGo to next message
Thanks ! just the thing Smile
toof
Re: AW 11 guys, brake pad suggestions Mon, 01 November 2004 01:27 Go to previous messageGo to next message
ive never been impressed with the aw11 stock brakes Sad
admittidly ive never spent a *fortune* on pads (spell ebc Razz)
but with half decent pads bendix metal ive found the stock calipers were pretty poor.
what ive done is swapped the stock calipers for a set of ST185RC twin piston numbers. even with the same type of bendix pads in there they work orders of magnitiude better. and to boot its a straight bolt up job. only mod required is cut a little of the dust shild out, other then that they bolt straight up to the old hubs on the stock rotors. they work *MUCH* better Smile
that said if you want some bendix metal pads for the stock calipers ive got a set here that have been bedded in properly then the grand total of about 800km on them. normally about $75 will sell for $50.
pm me or phone if your are interested in the pads 0412 352522
http://members.iinet.net.au/~toof/IMG_0740a.jpg
http://members.iinet.net.au/~toof/IMG_1172a.jpg
http://members.iinet.net.au/~toof/IMG_1187a.jpg
other wise my suggestion would be the new calipers. set you back between $100-200 for a pair and about $100 for a set of bendix metal. throw some new fluid behind them and your laughing Smile
[Updated on: Mon, 01 November 2004 01:28]
mk1sc
Re: AW 11 guys, brake pad suggestions Mon, 01 November 2004 08:15 Go to previous messageGo to next message
i've got adb front semi metallic pads
cheapy $30 stuff. not great stopping but i bought it coz it was cheap and does the job for normal driving plus my rotors are scored and too thin to machine
my next pad change will be better ones with new rotors
adamb131
Re: AW 11 guys, brake pad suggestions Mon, 01 November 2004 08:32 Go to previous messageGo to next message
I got toyota OEM on my NA and endless on my SC.
The Toyota pads have better inital bite and pedal feel... but run out pretty fast after about 3-4 hard brakes.
With the Endless pads the pedal is a lot squishier but you can stand on them hard all day and they keep working.
Also, to note, the endless pads have unexpectedly locked the fronts once or twice
Guess it depends on your application... for general use the Toyota ones are very good IMHO.
feral4mr2
Bundaberg, Qld.
Re: AW 11 guys, brake pad suggestions Mon, 01 November 2004 13:29 Go to previous messageGo to next message
toof, very interesting about the use of the ST185RC front calipers. does that vehicle also have rear calipers that are better then our stock rear ones? and basicaly bolt on...
i am useing the Bendix ultimate pads on the front and Bendix advance on the rear with stock calipers and rotors. Bendix dont do the ultimate's for the rear.. grrr
i need to get new front rotors and put a kit through my brake master cylinder before i can even call my brakes any good at the moment.
toof
Re: AW 11 guys, brake pad suggestions Mon, 01 November 2004 22:34 Go to previous messageGo to next message
i didnt think bendix made ultimate for the aw11 at all ?
as far as a rear caliper upgrade is concerend i havent looked into it. the new fronts doa good enogh job and they dont knock the balance out. the fronts will lock up first but they provide more then enough braking power, esp with only 115hp behind them. time will tell when i get my new s/c one here. ive got another set of front st185rc calipers for it already.
i think there is a little more space for a slightly larger rotor in there but not bu much if you didnt want to make up spacers to sit the caliper further out. a slightly thinker rotor probaly woudnt hurt just for some extra cooling but other then they they keep copping abuse with good heart. i havent managed to cook them, and not through lack of trying Razz
as far a rears i havent looked into it but i think i heard somewhere rear sw20 numbers perhaps ?
gearb0x
Re: AW 11 guys, brake pad suggestions Mon, 01 November 2004 22:41 Go to previous messageGo to next message
when you say you are not impressed with the stock MR2 brakes i was wondering what year (na/sc?) mr2 you are going by
Im pretty impressed with the brakes on my MR2 (87 SC), never get fade at all, and im still using what ever pads came on it from japan hehe
Id only think about upgrading them if i went to a 4agte
davedave
Re: AW 11 guys, brake pad suggestions Mon, 01 November 2004 23:57 Go to previous messageGo to next message
At the moment I have stock brakes on my 89NA, and it stops on a dime. I do have fairly new rotors & ferrodo pads though.
I have a set of the ST185 twin piston jobbies and rotors to go on mine when I do the conversion this month, and if it wasn't for engineering purposes, I don't think I would bother.
Amund in Norway did this extact thing and said the only thing you have to do to fit the ST185 rotors as well is drill the 4x100 holes.
http://www.mr2oc.com/showthread.php?s=&threadi d=11884&perpage=30&pagenumber=1
toof
Re: AW 11 guys, brake pad suggestions Tue, 02 November 2004 02:25 Go to previous messageGo to next message
5/89 N/A aussie delivered.
you could stomp them as hard as ou wanted and it just woudnt stop quick enough. it could be the claipers were in need ofa rebuild, it originally has mystery pads in there, replaced them with bendix metal and it was better but not fantastic. i had purchased the 185 calipers for my st184 but found i would need to do more playing around then i could be arsed doing, so i had them sitting in the shed. then in a moment of brilliance/madness i thought "wonder if they'll fit on this" and sure enough they do... and to boot they fit under the stock 14x6" rims too.
davedave
Re: AW 11 guys, brake pad suggestions Tue, 02 November 2004 02:56 Go to previous messageGo to next message
toof wrote on Tue, 02 November 2004 13:25
Don't tell my gf that, my excuse to buy the 16" simmons was to fit the bigger brakes underneath.
Seriously though, if I stand on my brakes they'll lock up, but if I give them a pretty good squeeze it will lift me off the seat. If there were no seat belts installed, there'd be a nice smudgey on my windscreen from my face Smiley =
toof
Re: AW 11 guys, brake pad suggestions Tue, 02 November 2004 03:08 Go to previous messageGo to next message
im guessing the calipers were in need of a rebuild then. either way the new ones certainly stop it alright Smile
the new stoppers leave some nice face prints on the windshield...
oh and of *course* you need some 16" rims to fit them in. 14" will never do the trick.. Razz
Benno
NSW Australia
Re: AW 11 guys, brake pad suggestions Wed, 03 November 2004 03:29 Go to previous messageGo to next message
Hey Toof.
I have followed your suggestion and purchased a set of ST185RC calipers, no point in wasting money on pads when i can get more swept area with these. Thanks for the tip Smile Smile Smile. Just need some braided lines now Surprised BTW they cost me $250 from just jap.
davedave
Re: AW 11 guys, brake pad suggestions Wed, 03 November 2004 03:58 Go to previous messageGo to next message
Did yours come with pads and all of the clips?
I bought my set privately and I'm missing everything besides the main unit. In the EPC I can find a 'pad' kit which seems to have everything included, and I'm about to enquire (through trade contacts) to get it from toyota japan.
Before I do, anyone know of any alternatives? If not, is anyone interested in my findings, I can keep you informed and if it's available possibly order multiple.
Also, for those running st185rc calipers (I should really ask this in another thread) where did you get your pads, are you using pads from a different car? Shops only have the single piston variety listed.
Joshstix
Re: AW 11 guys, brake pad suggestions Wed, 03 November 2004 05:27 Go to previous messageGo to next message
I'm actually planning on redrilling a set of later model ST185 disks and using the sigle piston ST185 caliper. The disk matches on hat size and centre bore etc, the only problem is the the stud pattern. The St185 disks are 278mm x 25mm as oposed to the AW11 front rotors that are 258mm x 22mm.
These bolt straight onto the twin spot hubs they just have a longer bracket that mounts the caliper further from the axle allowing a bigger rotor. I'll have to remove the splash guard but who cares.
I find the old DBA catalog pretty handy for this kind of thing. If you want to compare the specs for yourself take a look at http://www.dba.com.au/dba_catalogue_2004/HTML/pdf/ Out/Toyota.pdf.
4agte
Toronto, Downtown
Re: AW 11 guys, brake pad suggestions Wed, 03 November 2004 13:03 Go to previous messageGo to next message
i use lucas pads on the front which seem to pull up quite well and work well when cold. They didn't fade after constant abuse at wakefield and they were clamping n/a discs with a supercharged engine so they have less vaccume. That st185 upgrade sounds like the goods to me how much do the calipers cost and which wreckers did u get them from davedave?
davedave
Re: AW 11 guys, brake pad suggestions Thu, 04 November 2004 05:58 Go to previous messageGo to next message
Picked my calipers and freshly machined rotors up from someone here on the forums for the very nice price of $200 Very Happy
toof
Re: AW 11 guys, brake pad suggestions Sat, 06 November 2004 02:25 Go to previous messageGo to next message
i had a nightmare trying to get pads.. no one lists the twin piston numbers. EBC lists the WRONG part. got green stuff's the gt4 pad they list is NOT a gt4 pad it fits straight inot my ST184 !! but your in luck, after that ordeal it turns out the pad is the same form the twin piston to the single. i am currently running the bendix metal DB1181 (iirc) works a treat. not the best pad in thw world but good for 90 bucks.
i feel fantastic now, i paid $120 inc freight for mine Razz
brake line wise i fitted my calipers straight to the factory aw11 hose. it fits ok, but if too tight to fully open the caliper with it on so to change pads you'll need to change fluid as well. not that big an issue i guess.
as far as the st185 rotors fitting ill believe it when i see it, (278-257)/2 = would me there would need to be 10.5 of clearance between the bridge of the caliper and the rotor and i swear there isnt that much clearance.
davedave
Re: AW 11 guys, brake pad suggestions Sun, 07 November 2004 23:59 Go to previous messageGo to next message
120 for the calipers is a steal!
The 278mm ones are the single piston, the twin piston are similar spec to the 258mm aw11 ones.
I just measured mine with a dodgy 150mm ruler and got 255mm diameter, 24mm wide and 54mm centre hole.
With those measurements I think I might stick with my aw11 rotors, as I know they're newish and I won't have to redrill holes.
Joshstix
Re: AW 11 guys, brake pad suggestions Mon, 08 November 2004 00:21 Go to previous message
toof wrote on Sat, 06 November 2004 13:25
The single piston calipers and large discs are a direct replacement for the small discs and twin piston calipers on the GT4. The mounting bracket for the caliper is longer to mount the caliper further from the axle and allow a larger disk.
Once I get a set of disks and calipers I'll fit them up and take a few pics.
Previous Topic:DIY Fibreglassing
Next Topic:Blacktop Fuel Controller
Current Time: Fri Oct 30 07:54:38 UTC 2026
Total time taken to generate the page: 0.0067389011383057 seconds
