Toymods » Tech & Conversions » Toyota SC14 Supercharger pros/cons on small diesel
wagonist
Toymods Club Treasurer
Toyota SC14 Supercharger pros/cons on small diesel Mon, 01 November 2004 03:59 Go to next message
I've been thinking about taking the turbo off my car & installing a 1G-GZE sueprcharger instead.
Before reading any further it pays to note that my engine is a Toyota 2C-T 2.0L turbo diesel FWD.
Main reason is lack of boost when I'm trying to get out of corners. current max boost (stock) is about 12psi & the earliest I can get this is about 2200rpm.Seeing as my "power band" is between 1500rpm & 3500rpm with redline at 5200rpm.
Power torque is at 2400rpm & peak power is at 3800rpm.
The inlet piping is extremely short as there's no intercooler or throttle body.
What kind of reliable boost can be gotten out of the SC14?
How is boost pressure related to revs?
The engine is extremely rarely revved past 4000rpm as its getting right out the torque curve & will accelerate faster in the next gear.
Maybe because of this it could be overdriven more than Toyota allowed for on the petrol motors?
Opinions?
Oops, wrong section, please move me to Tech & Conversions.
[Updated on: Mon, 01 November 2004 04:14]
Skip
Re: Toyota SC14 Supercharger pros/cons on small diesel Mon, 01 November 2004 04:33 Go to previous messageGo to next message
I think it would be a whole lot of heartache for little if any gain, you could easily destroy the performance as much as you could improve it. But if you like a challenge go for it.
rob_RA40
c'town, NSW
Re: Toyota SC14 Supercharger pros/cons on small diesel Mon, 01 November 2004 04:42 Go to previous messageGo to next message
considered another turbo built up that will suit your needs?
rather than going thru the fuss of getting a SC in there.
Re: Toyota SC14 Supercharger pros/cons on small diesel Mon, 01 November 2004 04:59 Go to previous messageGo to next message
i'd be comparing the air flow from the turbo and choosing an appropriate SC or turbo based on that.
AFAIK, diesel requires much more air than similar capacity petrol engine. You might might that the SC14 quickly dies (from 100% duty), or simply runs out of puff before you get out of torque band.
a vortech or an eaton might be more what you're after?
Re: Toyota SC14 Supercharger pros/cons on small diesel Mon, 01 November 2004 05:34 Go to previous messageGo to next message
A piston engine is a positive-displacement pump... I can't see how a diesel engine is going to displace any more air than a petrol engine of the same size at the same RPM, unless the diesel has significantly higher VE? (Unlikely methinks).
Re: Toyota SC14 Supercharger pros/cons on small diesel Mon, 01 November 2004 06:26 Go to previous messageGo to next message
agreed Norbie,
but a diesel is effectively at WOT (with respect to air) all the time.. it' the fuel that throttles (do i have that right?)
the SC14 does the job on a 2L petrol motor.. it displaces 1.4L.
to provide 2L of air, it needs to be overspun 43%.
to provide 12psi, say you need to push about 1 bar with SC.. ie 4L/1.4 = SC speed = 2.86 times that of motor.
SC14 has top speed of what? 14000rpm??
14000/2.86 = 4900rpm.
sounds, on paper, to be just perfect Smile the problem with overspinning the SC on a 1G is that they run out of revs or blower spins too fast..
with the diesel, you will only just overspin by redline (although you could gear back a little, sayy 2.7 x motor speed)
you will however, increae parasitic drag on the motor, but since you are not going to high revs anyway, this won't be that much of an issue...
what you will get is maximum torque from near idle Very Happy
Re: Toyota SC14 Supercharger pros/cons on small diesel Mon, 01 November 2004 08:25 Go to previous messageGo to next message
you'd also be looking at tinkering with the fueling to get the power output up - no point in ramming in more air, if there's not enough fuel.
regarding volume of air needed, i'm guilty of having very little knowledge of the subject. sorry 'bout that. I just figured that with an already high compression ratio, you'ld need to shove in a lot more air and fuel to make a decent improvement in performance? a wild guess. Smile
also, is the 1G-GZE setup like the 4AGZE with the bypass valve? how would you plumb that in given that there is no TB? or if it's running 100% duty, how long would it last?
and don't truck turbo tend to have very different characteristics from their hi-revving petrol siblings? significant gas flow from the exhaust, but limited rev range?
Re: Toyota SC14 Supercharger pros/cons on small diesel Mon, 01 November 2004 08:48 Go to previous messageGo to next message
I'd be tempted to actually give it a go. I think that you want to make sure that you're using a decent flowing inlet manifold (the stocker looks a bit nasty..), a decent exhaust, and then you might need to start looking at the cam etc. a bit. After that, you'd definately need to start playing some games with the fuelling side of things. However, because the blower's airflow is related straight to RPM and (being no throttle) nothing else, whereas the turbo will spool up depending on engine load/fuelling, you'll find either one of two things:
1. You'll get fantastic fuel economy, because the blower is a more efficient air pump than the engine itself, and is essentially 'doing some of the work' of the engine all of the time, therefore decreasing pumping losses, as the blower is not throttled back like a spark ignition engine. You'll also find that you're keeping fantastic exhaust valve temperatures. The constant extra airflow will keep the combustion cooler, thereby allowing extra fuel to be added before the critical temperatures are reached, making more power when you want it. Also the loss of the restriction of the very tiny factory turbo will help greatly.
2. The thing will turn into a black smoking pig!
I'm leaning towards number 1 myself, and I'd be very interested to see how it goes if you do try it.
EVOSTi
cambo
      no
Re: Toyota SC14 Supercharger pros/cons on small diesel Mon, 01 November 2004 10:23 Go to previous messageGo to next message
my advice: dont fuck with diesels. the injector pumps are a PITA to get right. i havent seen your motor, but i assume its a distributor type pump. an even bigger pain than an inline pump.
wagonist
Re: Toyota SC14 Supercharger pros/cons on small diesel Tue, 02 November 2004 02:41 Go to previous messageGo to next message
I'll try to supply some more info about my engine.
Has a compression ratio of 24:1
Does not blow any black smoke. I run 20mL of injector cleaner with every refuel & this is evident by the lack of black residue on the back of my car (help when installed a dump pipe on the end of the exhaust instead of straight out)
Yes, it runs a mechanical injector pump which has a crude manual adjustment for fuel, but also has a computer attached to control the advance & amount of fuel relative to the boost level.
The turbo itself is not a problem. I don't know what turbo it is but it looks like the size of a CT20. It will however have different vane angles, etc.
The biggest problem is the exhaust manifold.
My engine is mounted east-west.
Due to the size of the injector pump, it ,and the inlet manifold, is mounted on the front of the motor with the p/s pump above & A/C comp below.
The turbo is a high mount on the back of the motor near the left end cylinder.
Underneath the exhaust manifold & above the steering rack, the the oil filter (100mm dia, 150mm long) is mounted horizontally.
The exhaust manifold itself is a log type with one side about 50mm away from the head. Therefore, no nice curves or merges. Just sharp right angles and T joints. And because of all the other things around it, a nice equal length smooth bended jobbie simply won't fit.
The inlet manifold is log type as well, with no throttle body & a turn around the left end of the head to aim at the turbo outlet.
I'm already running a 2.5" straight through exhaust, so that won't be an issue.
Yes, fuel delivery will have to be tinkered with, but as the engine is already designed to pump in more fuel (to a point) with more boost, this will only be a crude adjustment.
The main aim of the exercise is to have boost earlier to overcome the lag problem. I'm not interested in what happens past 4000rpm. If you've seen my torque curve, you'd see why.
Exhaust temp is a critical part of tuning a diesel. This is an indication of how hot the combustion is (too hot & the fuel ignites too early)
I'm already starting to look at how to fit a water-air intercooler in, plus engine oil cooler to help keep combustion temp down.
Skip
Re: Toyota SC14 Supercharger pros/cons on small diesel Tue, 02 November 2004 04:45 Go to previous messageGo to next message
Steve, I thought you said your engine was common rail?
More than likely you didnt though Razz
wagonist
Re: Toyota SC14 Supercharger pros/cons on small diesel Tue, 02 November 2004 04:49 Go to previous messageGo to next message
No, the next model had common rail.
I'll get a pic of my engine bay & post it up tomorrow.
Skip
Thats right if you keep feeding a diesel more fuel it will continue to make more power (airflow dependent though), unlike a petrol which will get rich and lose power. Unfortunately with the diesel the more fuel you inject the hotter the combustion which is what will kill a diesel engine, heat.
[Updated on: Tue, 02 November 2004 04:50]
EVOSTi
cambo
      no
Re: Toyota SC14 Supercharger pros/cons on small diesel Tue, 02 November 2004 06:09 Go to previous messageGo to next message
exactly. the accelerator pump acts on the govenor which alters the amount of fuel to determine engine speed. for a $0 power increase you can alter the govenor stop screw for more power. but as skip said, its heat that kills diesels. if your determined to get more power out of your diesel, the first thing you want to do is get a nice big oil cooler.
so what pump do you have, distributor or inline?
wagonist
Re: Toyota SC14 Supercharger pros/cons on small diesel Wed, 03 November 2004 00:39 Go to previous messageGo to next message
Distributor.
And as Skip quoted me, I know that heat is the killer.
I'm in the process of getting a temp guage to attach to the exhaust for this reason.
How does the supercharger's boost respond relative to it revs?
Re: Toyota SC14 Supercharger pros/cons on small diesel Wed, 03 November 2004 00:58 Go to previous messageGo to next message
wagonist wrote on Wed, 03 November 2004 11:39
linear.
as it is a positive displacement pump, it will output 1.4L of room pressure air per revolution. this will become less volume as it's pressurised, and the higher the output pressure, the greater the temp rise at the outlet.
with an SC, you should get near max boost from idle upwards.. ther eis no lag. the only thign is that at low rpm, the cam profiles may be such that some of the intake charge is blown out the exhaust due to valve overlap.
if you think you can put in more fuel (or the motor already puts in enough fuel at these lower rpm) then using an SC will make boost much much earlier than the turbo...
onl;y problem i see is that your fuel economy will suffer.... particularly if the SC is pumping all the time, and that much air is not needed.. you could experiment with throttling the intake of the SC, such that on highway/cruise, you are not forcibly pumping so much air.. the turbo, running off "free" exhaust power, would usually increase highway economy...
a water to air IC will make a big difference to intake temps and is probably recommended...
i reckon just give it a go.. would be pretty cheap to set up, and you don't have to worry about AFR like the rest of us... at worst, if the pump doesn't supply thr fuel down low, you will just have a bit more parasitic drag from pumping air, but as soon as the fuel is available, the power will be made... will make an already torquey motor just that much more "stout"
wagonist
Re: Toyota SC14 Supercharger pros/cons on small diesel Wed, 03 November 2004 01:13 Go to previous messageGo to next message
Sorry, I don't quite get that.
If the boost reponds linearly to the SC revs (which is relative to the engine revs) then you're going to have max boost at max engine revs.
How do you get max boost at near idle then?
Is it is function of the supercharger design?
or does it vent the excess pressure after a point?
Not particularly worried about the fuel economy (I get about 700km/60L around town & I've done Sydney to Brisbane, 890km, on 58L)
Plus my car is strictly an after hours car as I bring home a work vehicle.
Re: Toyota SC14 Supercharger pros/cons on small diesel Wed, 03 November 2004 01:29 Go to previous messageGo to next message
wagonist wrote on Wed, 03 November 2004 12:13
well...
it is a positive displacement pump. it is a function of the SC's design...
that means that for each revolution, a certain amount of air is moved, regardless of rpm. look at the pics below... the air actually moves around the OUTSIDE of the casing, and the inside part where the lobes mesh SEALS the center of the SC...
unlike a turbo, at idle rpm, the SC will move 1.4L of air per SCrevolution. at high rpm, the SC will move 1.4L of air per SCrevolution. the boost is then just a result of how much air doesn't get into the engine! or more simply, if the engine capacity is less than the SC's capacity x the drive ratio, then there will be intake pressure.
http://www.fefcholden.org.au/techinfo/supercharge/images/rootes.jpg
http://www.ic.sunysb.edu/Stu/rrupnick/Supercharger_files/image013.jpg
a turbo on the other hand requires exhaust energy to get the turbine and thus compressor spinning.. you have to wait until there is enough exhaust to move enough intake charge, to make enough exhaust to make enough intake charge to make boost Wink
the downside of an SC is that the losses increase by the square of rpm, ie the power required to drive it increases with rpm. the heat generated will also increase with rpm...
if you are driving the SC at 'normal' SC speeds, then the losses will not be huge (maybe 10hp? at most).
an SC is less efficient at compressing air (i think) since the compression only happens when the room pressure air contained by the lobes, hits the already pressurised air in the intake... causing heat to be generated..
twisted lobe SC's like:
http://us1.webpublications.com.au/static/images/articles/i11/1102_4mg.jpg
have less of a pressure pulsation, and thus less heat generated, and are more efficient...
so anyway, the amount of air moved by the SC is linear with rpm. if the amount of air consumed by the engine is linear with rpm, then the resulting boost will also be linear. there will be fluctations due to engine efficiency and cam profiles, but compared to a turbo? linear boost with RPM..
Skip
Re: Toyota SC14 Supercharger pros/cons on small diesel Wed, 03 November 2004 01:43 Go to previous messageGo to next message
My Navara has a butterfly between the turbo outlet and intake manifold. It remains closed (not completely) then when the engine comes on boost it completely opens. These are the only two modes it has opened or closed. Was quite funny watching it on the dyno. Anyways what exactly would the purpose of this butterfly be?
wagonist
Re: Toyota SC14 Supercharger pros/cons on small diesel Wed, 03 November 2004 02:13 Go to previous messageGo to next message
Thanks.
Very nice explanation.
a 10hp loss on my car over the existing would be noticable.
Best figure I've got on a dyno is 49.5kW at the wheels.
as I've described earlier, I think the biggest problem with the lag is caused by the exhaust manifold restricting flow.
EVOSTi
cambo
      no
Re: Toyota SC14 Supercharger pros/cons on small diesel Wed, 03 November 2004 10:16 Go to previous messageGo to next message
Skip, if you have a closer look you will notice a venturi with the butterfly, just like a carby. this is to provide a vacuum for the govenor and whatever. its just there cause a diesel inlet manifold has no vacuum, thats why it needs a vacuum pump on the back of the altenator.
boxh34d
wangaratta
Re: Toyota SC14 Supercharger pros/cons on small diesel Wed, 03 November 2004 11:12 Go to previous messageGo to next message
wagonist:
although a SC may cost you 10 HP to run, a turbo has power losses that come with it too, its just that they are harder to measure.
a crappy manifold design, and the turbine and housing restricting exhaust flow restrict power in a turbo engine.
just something to consider. . .
Re: Toyota SC14 Supercharger pros/cons on small diesel Wed, 03 November 2004 14:03 Go to previous messageGo to next message
ahh, good point Smile turbo has backpressure as well as the crappy manifolds...
the SC may not be 10hp tho... there must be some data around... failing that you could use Eaton M90 data as a maximum..
wagonist
Re: Toyota SC14 Supercharger pros/cons on small diesel Wed, 03 November 2004 22:27 Go to previous message
The turbine housings are generally smaller on a diesel compared to a similar petrol engine.
Is it true that exhaust gas speed is higher in a diesel?
I imagine that 24:1 compression ratio compared to 10:1 would try to "squeeze" the gas out faster.
Would that be the reason why I can get 12psi at only around 2000rpm?
Previous Topic:100kw piston ring size?
Next Topic:Can't find Coiloversor camber adjustment plates for aw11s
Current Time: Fri Nov 20 23:11:59 UTC 2026
Total time taken to generate the page: 0.0070149898529053 seconds
