Toymods » Tech & Conversions » AE86 radiators, what do you use?
drift86levin
brisvegas
AE86 radiators, what do you use? Mon, 01 November 2004 05:25 Go to next message
after finding a small crack in my rad..i decided to take a trip down to the wreckers with a tape mesure and get some sort of replacement..i found on a nissan shelf..a 3 core rad which a radiator place thinks is from an Urvan..bottom hose is good..and the top hose is on the other side..fortunatly supercheap..repco..etc stock a long S shape that goes straight on! $50 to flush/reco the rad..$50 for the rad in the first place..so $100 plus $20 for the hoses.. and i came away with a 3 core rad that literally holds three times the capacity of the old one..
what is the normal upgrade for 86's?
Re: AE86 radiators, what do you use? Mon, 01 November 2004 05:32 Go to previous messageGo to next message
I use a Hyundai Excel radiator. has a electric thermo attached and temp switch in the radiator. $50 Smile
EVOSTi
cambo
      no
Re: AE86 radiators, what do you use? Mon, 01 November 2004 10:27 Go to previous messageGo to next message
this has been covered pretty extensively. basically your gonna need to make custom brackets however you go so just go to the wreckers, find one that physically fits and is atleast twin core, and go from there.
NickAE86
Brisvegas
Re: AE86 radiators, what do you use? Mon, 01 November 2004 11:24 Go to previous messageGo to next message
hiace seems to work well...looks a little chunky but doesnt require much to fit apart from the brackets as evosti mentioned
joyride
fairfield NSW
Re: AE86 radiators, what do you use? Mon, 01 November 2004 12:38 Go to previous messageGo to next message
im using one from a current model tarago. its got some twin loop system (farked if i know what it means) but its got a large surface area.
truenosedan
Re: AE86 radiators, what do you use? Tue, 02 November 2004 01:05 Go to previous messageGo to next message
i THINK mine is a camry one, it is single core but it is massive, and has a davies craig thermo fan wired to the cabin and run toyota red Very Happy and a new water pump and a new thermo, no overheating problems here... Very Happy my rad is a close to perfect fit, except frontal area is huge...
fOOZ86
Re: AE86 radiators, what do you use? Tue, 02 November 2004 01:16 Go to previous messageGo to next message
I use the standard one that came with the 4AC, now running a 4age bigport it's only ever had problems cooling the engine after a day on the skidpan..
It's fine in the hills too!
Sam_Q
S.E suberbs, Vic
Re: AE86 radiators, what do you use? Tue, 02 November 2004 02:44 Go to previous message
Hyundai Excel:
http://member.telpacific.com.au/sam/other/rad06.jpg
or go to here to see the process involved to put it in:
http://tacticalevo22.proboards7.com/index.cgi?boar d=project&num=1094051575&action=display&am p;start=0
and yes that is a 4Ac, its a work in progress.
Previous Topic:What car did the 86kw rwd 4a-ge come out of?
Next Topic:Stupid Question But Just curious. 4A block (was 4A-C) + 4A-GE Head (from 4A-GE obviously)
Current Time: Thu Nov 19 05:12:22 UTC 2026
Total time taken to generate the page: 0.0068039894104004 seconds
