| Author | Topic |
AE86 RCA Install
Mon, 01 November 2004 06:54
Having some trouble removing the 17mm bolts that are underneath the strut assembly... i got one off but the other 3 aren't budging..
is there a special way to do it that im missing out? its fucking impossible!!!!
thanks guys
shiri
Re: AE86 RCA Install
Mon, 01 November 2004 06:59
big long breaker bar or rattle gun
Mon, 01 November 2004 07:00
also coat liberally with crc, wd40 helps. tap bolt head with hammer
have neither of them
Mon, 01 November 2004 07:29
Get some decent tools, or else you are gonna round off the bolts, then you are really stuffed.
Impacts are nice, but you can get everything off with a decent set of sockets a breaker bar and a big pipe.
Apparently you can move the earth by yourself if you have a long enough lever.
O yeah, turn the steering wheel to give you a better shot at the bolt.
dodgydan
Mon, 01 November 2004 09:15
What they all said. WD40 is like $5 a can, and the big one I have has lasted about 2 years. Go do it.
Also, turn the wheel so that the bolt is in a nice spot then take the keys out so the steering lock engages, keeping everything steady. Use a quality ring spanner or socket.
And when refitting with RCAs in there you'll need to be brutal/creative to get the strut sitting right on the steering knuckle.
Hen
