Toymods » Tech & Conversions » 1G-GTE Speedo
Crossy
1G-GTE Speedo Mon, 01 November 2004 07:33 Go to next message
i need an electronic speedo transducer for my 1G-GTE 5 speed...
did they eva come with them stock or only cable type speedo..
is this an easy thing to get a ahold of?
if not does ne one know of ne other types of cars that i can pinch one out of
thanx heaps
MaT
sideshow
Re: 1G-GTE Speedo Mon, 01 November 2004 11:57 Go to previous messageGo to next message
i sell the electronic devices that screw onto yr speedo drive on gbox
do u know what pulses they are
i have 4 pulse 5 pulse 10 pulse and 20 pulse
usually toyota will either be 4 or 20 pusles
Crossy
Re: 1G-GTE Speedo Tue, 02 November 2004 06:09 Go to previous messageGo to next message
I don't think it matters what it is...
i have a new VDO speedo and it has inbuilt calibration settings...
all i would need to know is how many pulses it has per KM and punch it into my speedo to calibrate it
how much would i be looking for these senders delivered...
i'm in melbourne... eastern suburbs
sideshow
Re: 1G-GTE Speedo Tue, 02 November 2004 09:53 Go to previous messageGo to next message
well i sell new devices and 2nd hand ones if u want some
Les
Re: 1G-GTE Speedo Tue, 02 November 2004 11:04 Go to previous messageGo to next message
sorry to hijack, but sideshow, how do i get my speedo and tacho readings correct ?? they are pretty out of wack prolly due to installation of new gearbox ... ?
Re: 1G-GTE Speedo Tue, 02 November 2004 11:10 Go to previous messageGo to next message
I'm not sideshow but.
To get your speedo working correctly, you need to use the speedo gear from your cars original gearbox (was manual right?). This is providing you haven't screwed it with diff ratios or wheels.
To get the tacho working, you'll most likely need to get it recalibrated for a 6. There are plenty of places that can do this for you.
sideshow
Re: 1G-GTE Speedo Tue, 02 November 2004 22:03 Go to previous messageGo to next message
i am sideshow Smile
if yr speedo is out by a fraction u can get
electronic speedo ratio boxes which u can adjust the output to recalibrate the sppedo
these can also be used when fitting a 6cyl engine to a 4cyl tacho they cost about 200 bucks
so if u dont want to fart ass around removing dash and gettin yr tacho redone then this is easier way
to get tacho redone will cost about 100 to 150 depending what is needed
Dirty_Sanchez
Re: 1G-GTE Speedo Wed, 03 November 2004 00:35 Go to previous messageGo to next message
sideshow, do you sell these kits? i want to get the tacho hooked up in my sprinter and i'm not sure as to exactly what i need.
i got a 1g as well.
sideshow
Re: 1G-GTE Speedo Wed, 03 November 2004 02:00 Go to previous messageGo to next message
does yr tacho work in the sprinter from the 1gg
if it does but is inaccurate
then u can use one of these devices
i can set these devices up so it will work when fitting a 6cyl to a 4cyl tacho
if it doesnt work u might need a signal booster and then one of these devices
i make small signal boosters plus i also have ones from sixworks
the proper tacho signal from a 1gg is weak for a sprinter tacho i think
i can sell u the device to make yr tacho read accurate and ill throw in the tacho signal booster that i make
these usually work on sprinters when hooked up with microtechs and 4agzes
[Updated on: Wed, 03 November 2004 02:01]
Dirty_Sanchez
Re: 1G-GTE Speedo Wed, 03 November 2004 02:14 Go to previous messageGo to next message
the speedo works fine but the tacho isn't hooked up. I've been wanting to hook it up but people have told me that it needs to be recalibtrated and that sprinter tachos use different signals than what a 1ggte puts out.
I'm a bit lost with it all and i would love a A to B answer as to how i can hook this tacho up.
(sorry for thread hogging Embarassed )
sideshow
Re: 1G-GTE Speedo Wed, 03 November 2004 02:34 Go to previous messageGo to next message
well the sprinte has a 4cyl tacho
with the 1gg being a 6cyl yr tacho will read 1200 rpm when the engine is at 800 rpm
plus yr sprinter tacho runs off neg coil
where yr 1gg tacho would run of the ig- signal from the ignitor
i sell 4 types of signal boosters
prices range from 30 to 150 bucks
the commomn one i use on microtechs and sprinters is the cheaper one
even if u get tacho working with signal booster it will still be innacurate
so thats where you need an electronic ratio box
so u have to decide which way to go
either get tacho modified to suit the weak 1gg signal and also modified to suit a 6cyl engine
or fit a signal booster and an electronic ratio box
i can supply u an electronic ratio box and signal booster
Crossy
Re: 1G-GTE Speedo Wed, 03 November 2004 08:24 Go to previous messageGo to next message
sideshow wrote on Tue, 02 November 2004 20:53
cost to me?
sideshow
Re: 1G-GTE Speedo Wed, 03 November 2004 09:22 Go to previous messageGo to next message
the devies i have 2nd hand are for yr speedo
they the speedo sensors on the gboxs i have collected
over the years
if thats what u need then say bout 30 bucks for one
the elcetronic device to adjust yr tacho is new
Crossy
Re: 1G-GTE Speedo Wed, 03 November 2004 09:27 Go to previous messageGo to next message
so for an electronic speedo drive for my supra 5 speed....
you have one that would work... for about 30 bucks
can you deliver to melbourne?
sideshow
Re: 1G-GTE Speedo Wed, 03 November 2004 09:56 Go to previous message
the device i have will screw onto the speedo drive on your gbox
it has 4 pulses every revolution
this is most common
i also have 20 pulse sensors
Previous Topic:Power Steering Belt, Lower Pulley
Next Topic:starter problems =
Current Time: Tue Oct 20 22:54:17 UTC 2026
Total time taken to generate the page: 0.0066728591918945 seconds
