Toymods » Tech & Conversions » Can i buy a bellhousing that will bolt up to a 1G and my W55 ?
Mookie
Tassie
Can i buy a bellhousing that will bolt up to a 1G and my W55 ? Mon, 01 November 2004 07:46 Go to next message
I don't want to have to buy a new gearbox as i like my gearbox and have one as a spare.
I was wondering if there was a bellhousing i could to go between the 1GGTE and my w55 gearbox ?
if not can i get one custom made ?
Re: Can i buy a bellhousing that will bolt up to a 1G and my W55 ? Mon, 01 November 2004 07:52 Go to previous messageGo to next message
A G-series bellhousing will bolt straight up to your W55. That said, finding one without a gearbox attached might be a PITA.
Mookie
Tassie
Re: Can i buy a bellhousing that will bolt up to a 1G and my W55 ? Mon, 01 November 2004 07:56 Go to previous messageGo to next message
I'm getting everything i need on a palatte instead of buying a 1/2 cut.
So i'll just ask him to chuck a bellhousing on it
TRD_Celica
Hobart
Re: Can i buy a bellhousing that will bolt up to a 1G and my W55 ? Mon, 01 November 2004 22:14 Go to previous messageGo to next message
when are u doing yer crazy convertion ? which celica r u putting it in?? the gold one or the blue one ?
MR 1JZ
Re: Can i buy a bellhousing that will bolt up to a 1G and my W55 ? Mon, 01 November 2004 22:17 Go to previous messageGo to next message
how does a W55 go at holding any decent power from a 1GGTE, becuase i have a feeling I can find one fairly cheaply Smile
TRD_Celica
Hobart
Re: Can i buy a bellhousing that will bolt up to a 1G and my W55 ? Mon, 01 November 2004 22:31 Go to previous messageGo to next message
is the W55 the stock box in the SA63 ? cause my RA60 had a W57
MR 1JZ
Re: Can i buy a bellhousing that will bolt up to a 1G and my W55 ? Mon, 01 November 2004 22:33 Go to previous messageGo to next message
do all RA60's have W57's?
Manual ones obviously?
TRD_Celica
Hobart
Re: Can i buy a bellhousing that will bolt up to a 1G and my W55 ? Mon, 01 November 2004 22:38 Go to previous messageGo to next message
i spose so.. my mate has an RA60 and he has a w57.. quite a tough little box really Very Happy
MR 1JZ
Re: Can i buy a bellhousing that will bolt up to a 1G and my W55 ? Mon, 01 November 2004 22:58 Go to previous messageGo to next message
well i know where i can get a 1G bellhousing for a W57 cheap, and U pull it at lonsdale has about 15 RA60's one of them is bound to have a decent W57 in one of them, which is good becuase gearboxes are only $72 Very Happy
Is the clutch motor specific or gearbox specific?
TRD_Celica
Hobart
Re: Can i buy a bellhousing that will bolt up to a 1G and my W55 ? Mon, 01 November 2004 23:05 Go to previous messageGo to next message
BTW i sold my RA60 a few weeks ago.. so this is all for mookie not me!! But i would say the clutch would be gearbox that is if the engine comes with one!! I am looking at an Import SW20!!!
Re: Can i buy a bellhousing that will bolt up to a 1G and my W55 ? Tue, 02 November 2004 00:46 Go to previous messageGo to next message
Any of the W55,W57 and W58 boxes should be fine behind a 1GGTE.
MR 1JZ
Re: Can i buy a bellhousing that will bolt up to a 1G and my W55 ? Tue, 02 November 2004 00:57 Go to previous messageGo to next message
which bellhousing do i need?
i have a spare 1G bellhousing off an auto, but it is unlikely that would fit would it? Confused
also frank if i go to u pull it and grab a gearbox is it worth getting the clutch as well? or things like the master cylinder off the RA60?
What should i really be getting as it is dead set cheap at Upullit?
Re: Can i buy a bellhousing that will bolt up to a 1G and my W55 ? Tue, 02 November 2004 01:00 Go to previous messageGo to next message
You need a G-W5X bellhousing. You may as well find something fron an importers or putting wanted notices on Toymods, cos you'll need a 1G clutch and flywheel as well. Even if you get everything bar the gearbox from the importers and pick up one of these W57's.
MR 1JZ
Re: Can i buy a bellhousing that will bolt up to a 1G and my W55 ? Tue, 02 November 2004 01:08 Go to previous messageGo to next message
well id probably get a heavy duty clutch (brand spankers), flywheel is easy, clutch pedal comes straight out of an MA70 (i think/hope), can i use any master cylinder? for a W5X?
ra23celica
Re: Can i buy a bellhousing that will bolt up to a 1G and my W55 ? Tue, 02 November 2004 01:09 Go to previous messageGo to next message
W55, 57 and 58 gearboxes are rated at 200 - 250 flywheel horsepower, so they will be fine behind a std 1G-GTE.
You will find W57's in RA60's, W55's in SA63's and (low strength) W58's in RA65's.
I'm running the W57 from a RA60 behind my 1G-GZE in my RA23.
You will need a G series bellhousing, and in mine at least, a "G" was stamped on it at the gearbox end if memory serves.
Ask the seller to tell you the stamping on the bellhousing before he chucks it on the pallet. Otherwise you will get an R series bellhousing and that does not mate up to the 1G series engines.
Going rate for a G series bellhousing is $100 and upwards as they are a rare beast.
Good luck with it all.
Mitch.
ra23celica
Re: Can i buy a bellhousing that will bolt up to a 1G and my W55 ? Tue, 02 November 2004 01:14 Go to previous messageGo to next message
Your master cylinder choice will depend on your brakes, upgraded or not, more than what g/box you have. On std brakes a 15/16 MC is fine, just ensure that if you swap another MC onto your std vaccum booster that the rod inside the booster pushes the piston inside the MC the full length on its travel.
Been there, done that Sad
And another thing, while the g/box is on the garage floor, buy and fit a new slave cylinder onto it. They are about $33 from Repco, cheap insurance against later hassles.
Mitch.
Re: Can i buy a bellhousing that will bolt up to a 1G and my W55 ? Tue, 02 November 2004 01:16 Go to previous messageGo to next message
ra23celica wrote on Tue, 02 November 2004 09:14
I think he's talking about a clutch master cylinder dude.
ra23celica
And now that I read your post again I see you mean clutch MC, DOH ! Yes, the std clutch mc is fine, just change the slave cyl like I posted.
Confused Mitch.
MR 1JZ
Re: Can i buy a bellhousing that will bolt up to a 1G and my W55 ? Tue, 02 November 2004 02:02 Go to previous messageGo to next message
yeah i was gonna anyway, $33 saves some cash i spose, so i guess 170rwkw is out of the question with one of those RA60 W57's?
Re: Can i buy a bellhousing that will bolt up to a 1G and my W55 ? Tue, 02 November 2004 02:13 Go to previous messageGo to next message
Not unless you drive like a dickhead.
MR 1JZ
Re: Can i buy a bellhousing that will bolt up to a 1G and my W55 ? Tue, 02 November 2004 02:17 Go to previous messageGo to next message
justcallmefrank wrote on Tue, 02 November 2004 12:43
so drifting is out of the question?
Re: Can i buy a bellhousing that will bolt up to a 1G and my W55 ? Tue, 02 November 2004 02:19 Go to previous messageGo to next message
It may last fine, just look after it and remember, there is a difference between driving hard and doing something to break it...i.e. flatshifting is a stupid idea.
Re: Can i buy a bellhousing that will bolt up to a 1G and my W55 ? Tue, 02 November 2004 02:21 Go to previous messageGo to next message
It is? Shocked
http://members.optusnet.com.au/norbee/W57/W57_07.jpg
MR 1JZ
justcallmefrank wrote on Tue, 02 November 2004 12:49
not only is it stupid but it is pointless...Rolling Eyes
if you need to flatshift to win a drag then your car isnt fast enough
Norbie wrote on Tue, 02 November 2004 10:21
It is? Shocked
Yes short stuff, it is Laughing
ra23celica
Torque kills gearboxes more than outright power. Drifting kills drivetrains. W57 g/boxes should be pretty cheap were you are. If you are worried about breaking one, by a second one to fit when and if you break the first one. Swap it in when it does, and then drive like Elmer Fudd while you get your first g/box rebuilt with heavy duty internals.
If you never break the first box, sell your spare one.
Mitch.
MR 1JZ
Re: Can i buy a bellhousing that will bolt up to a 1G and my W55 ? Tue, 02 November 2004 02:25 Go to previous messageGo to next message
yeah RA23 i was thinking of just buying two of them when i go to get the first one, they are only 80 odd dollars each so its not as if its going to break the bank which is handy and once the hard work is done, i.e. finding bell housing, getting clutch modified, modifying tailshaft, fitting clutch pedal and master cylinder, fitting another gearbox should only be one days work at most Smile
Cheers for the help people and sorry for hijacking this thread, whomever it belonged too Smile
TRD_Celica
Hobart
Re: Can i buy a bellhousing that will bolt up to a 1G and my W55 ? Tue, 02 November 2004 03:01 Go to previous messageGo to next message
well as previously stated just don't drive it so hard.. don't intentionally try to break your gearbox W57 is tough as nails but anything is possible!! i would surgest putting a G'box from a hyundai Excel they are awesome or a Kia Rio
matt_84
Ipswich
Re: Can i buy a bellhousing that will bolt up to a 1G and my W55 ? Tue, 02 November 2004 03:48 Go to previous messageGo to next message
On this topic, how hard is it to find a suitable clutch relaease fork for the g series bellhousing? I'm buying a bare bellhousing, so i take it i will need to find;
clutch release fork
throwout bearing
slave cylinder
Is that it? Where can I get these off, any common donors?
HyDrA
Adelaide, SA
Re: Can i buy a bellhousing that will bolt up to a 1G and my W55 ? Tue, 02 November 2004 04:00 Go to previous messageGo to next message
For what it's worth, I have a W55 behind my 1G-GTE... it handles it pretty easily i'd say!
The ratio's might get annoying though.
Mookie
Tassie
Re: Can i buy a bellhousing that will bolt up to a 1G and my W55 ? Tue, 02 November 2004 05:29 Go to previous messageGo to next message
Wow lots of reply's awesome !!!
There is a good change i'll have to replace the diff so i'm assuming a supra diff with be ok ????
TRD: it's going into the blue celica i'm gunna keep the gold one bog stock that way i have something to compare my blue celica to.
Also the colt still hasn't has it's transplant Rolling Eyes
I plan to get a heavy duty clutch anywhay but i'm wondering what to buy for a SA63 or something else ??
Hydra: what do u mean the ratios will get annoying are they too close or too far apart ?
I plan on driving the car hard and it will have a few minor mods nothing extreme will the W55 still hold up ?
I'm going with a narrower tyre on the back so there shouldn't too much stress on the drivetrain
Thanks fellas Mookie
ra23celica
Re: Can i buy a bellhousing that will bolt up to a 1G and my W55 ? Tue, 02 November 2004 05:56 Go to previous messageGo to next message
matt 84 - slave cylinder we covered already, a xA60 series one from Repco for $33 odd dollars. I'm pretty sure the release fork is common to this vintage (W series), as is the throw-out bearing to suit whatever clutch you are running.
HyDrA - W55 ratio's are a bit strange I have found, maybe they better suit an NA car with its different power delivery compared to a turbo motor. I'm not sure, but a 55 is the last box I want to run behind a G series motor. I have a 57 as its 5th gear is not as overdriven as the one in the 58 box. 0.85 opposed to 0.75. You don't drop into such a great hole once you pull 5th, but a W58 would be better for a high horsepower high revving turbo motor.
Mookie - A Supra diff will cope fine *provided* you are not God's gift to drifting, burnout's, dough-nuts, circle work etc - like any diff in any car. F series (Supra/RA65 7.5 inch) are good strong units. The final drive ratio you want in an LSD might be harder to find, but they are out there. See a clutch specialist for the heavy duty unit you need. They will find / make the right unit to match your hardware and your driving style. Its worth the $400 to $500 you will spend on this - trust me you will hate dropping (and refitting) the gearbox and tail shaft once you start breaking a few std clutch's. Again - the W55 will hold up under pretty serious driving - don't be too silly about it for too long.....
[Updated on: Tue, 02 November 2004 06:00]
HyDrA
Adelaide, SA
Re: Can i buy a bellhousing that will bolt up to a 1G and my W55 ? Tue, 02 November 2004 06:18 Go to previous message
W55 is too close ratio for my liking, well, for my engine.
W58 is somewhere on my list of items to purchase... or a 6 speed from an IS200, that'd be cool.
Previous Topic:ST182 Brake Upgrade
Next Topic:1jz flywheel
Current Time: Thu Nov 19 00:59:27 UTC 2026
Total time taken to generate the page: 0.22969794273376 seconds
