Toymods » Tech & Conversions » water leak help
EvilJack
Sutho/Hills NSW
water leak help Mon, 01 November 2004 10:28 Go to next message
Have a water leak from below the thermostat housing, im guessing the gasket is gone but to get a closer look im wondering how to get the damn thing off.
Red arrow indicates the cause of leak, well what its come down too atm
Green arrow is im wondering if this pipe slides out either end ?
http://insertdomainnamehere.com/misc/leak%20001.jpg
Has anyone had any experience at pulling it off or any ideas of how to remove?
i have looked at removing the 2 bolts to the top left but theres still the water pipe connected to it further down, and its very very hard to get on the other side to remove the bolt. Rolling Eyes
Next picture below just shows an expanded view of what im actually talking about.
http://insertdomainnamehere.com/misc/leak%20002.jpg
Any help appreciated. Cool
[Updated on: Mon, 01 November 2004 10:30]
Adsport
Perth WA
Re: water leak help Thu, 18 November 2004 09:40 Go to previous messageGo to next message
looks similar to the 3a/4a rwd ones, on those you have to remove the top part aswell as the water pump and the rear facing hose, if thats any help.
dcleyne
Re: water leak help Thu, 18 November 2004 21:06 Go to previous messageGo to next message
If its the same as the 4A, then that pipe will have two o-rings, one at the top and one at the bottom. You'll have to remove the lower housing (take off the hose and get the other bolt out) and then it will pull away. When I did this job on my 4a-c, the reason it was leaking was the top of the pipe had corroded away and the o-ring had collapsed into the hole left by the corrosion. Be prepared to go to toyota looking for a new one. Mine cost $30 and they want $4 each for the o-rings Laughing
I went to clark rubber for those...
Dan
EvilJack
Sutho/Hills NSW
Re: water leak help Fri, 19 November 2004 02:16 Go to previous message
heh thanks guys, i got the exploded diagram of it...however i ended up pulling it off the way i said looked to hard Rolling Eyes
Previous Topic:mixture hypothesis
Next Topic:1jz - pipe near ISCV
Current Time: Sat Oct 17 03:46:25 UTC 2026
Total time taken to generate the page: 0.0049140453338623 seconds
