Toymods » Tech & Conversions » ST165 g/box (hypothetical)
RWDboy
ST165 g/box (hypothetical) Tue, 02 November 2004 10:31 Go to next message
Just wondering, the early early ST165s (1986 manufacture) had a manually locking centre diff, ie the car was in front wheel drive most of the time, or you could lock the centre and have 4 wheel drive.
Does this mean if you took one of these gearboxes, took the front driveshafts out of the car and then stuck it in 4WD mode, that you would have a rear wheel drive ST165?
Classique71
Colac, Victoria
Re: ST165 g/box (hypothetical) Tue, 02 November 2004 11:06 Go to previous messageGo to next message
Sorry no Wink
dreams!
much as id want it too , i dont think its capable with any gt4 box ..
PS: buy my st185 gearbox !
RWDboy
Re: ST165 g/box (hypothetical) Tue, 02 November 2004 11:42 Go to previous messageGo to next message
*hmmms* What's the deal there? Surely if it's a locked centre then as soon as there is no power to the fronts it simply goes to the rear...or is the mechanism incapable?
p.s. I have no money!
Re: ST165 g/box (hypothetical) Tue, 02 November 2004 12:45 Go to previous messageGo to next message
minispool the centre diff?
RWDboy
Re: ST165 g/box (hypothetical) Tue, 02 November 2004 12:58 Go to previous messageGo to next message
minispool? I'm a bit of a retard in this area...do you mean weld the viscous coupling together on a later GT4 box??
Re: ST165 g/box (hypothetical) Tue, 02 November 2004 13:10 Go to previous messageGo to next message
ahh umm... not having seen one i'm totally guessing, but if you replace it with a solid chunk of metal, as they do with rear differentials (ie mini/full spool/CIG locker), then it must transfer all power thru the diff.. it can't slip.
got a pic of the 'coupling'?
3S-GE_Man
Gold Coast
Re: ST165 g/box (hypothetical) Tue, 02 November 2004 14:22 Go to previous messageGo to next message
ummm. GT-4 rear diff's are LSD as standard!I'm sure!
and by my box it JDM st185 and it been sitting around for longer!
Nezza Cool
RWDboy
Re: ST165 g/box (hypothetical) Tue, 02 November 2004 17:38 Go to previous messageGo to next message
It's not really the rear diff that is the issue, it's the centre one.
I haven't taken a GT4 box apart yet - so that's why I'm a little flaky in this area.
Classique71
Colac, Victoria
Re: ST165 g/box (hypothetical) Wed, 03 November 2004 02:16 Go to previous messageGo to next message
if its anything setup like the st185 gearboxes that locker is only to be exploited in towing - it wouldnt be strong enough to handle total RWD power
the other option is north southing with a W series box and ma70 rear end Wink
PS 3sge man - PFFT to JDM - go teh ozspec!
RWDboy
Re: ST165 g/box (hypothetical) Wed, 03 November 2004 03:54 Go to previous message
Yeah I'm assuming that there would be strength issues, I know that wiso has locked a GT4 gearbox into FWD and hasn't had too many strength issues (after a few goes I think) so surely going the other way (RWD) wouldn't be worse.
The only reason I ask about this though is that the original ST165 wasn't all-wheel drive so the gearbox is probably quite different and it may be stronger with that kind of setup. Only problem is availability and the fact that it probably won't work.
Previous Topic:TA22 V EXA
Next Topic:7mgte conversion into ma61
Current Time: Fri Oct 16 15:34:24 UTC 2026
Total time taken to generate the page: 0.064200878143311 seconds
