Classifieds » Parts Wanted » 1ggte fuel regulator ... gen 3
Les
1ggte fuel regulator ... gen 3 Tue, 02 November 2004 12:20 Go to next message
does anyone have one lying around ?
need to see if it solves my fuel problem .. if it does, i will buy it off you Smiley =
Siktoy ra23
Plumpton/sydney
Re: 1ggte fuel regulator ... gen 3 Tue, 02 November 2004 12:32 Go to previous messageGo to next message
I have one some where in the shed Ill have a look for you
P.S what is the problem?
Ben
Les
Re: 1ggte fuel regulator ... gen 3 Tue, 02 November 2004 12:45 Go to previous messageGo to next message
Here goes ...
1) original internal RA65 fuel pump leaned out when i gunned it
2) purchased an external VL fuel pump 2 use as as main pump ie placed in fuel lines (used original as a feeder pump to the VL as main) ...
car would do funny shit i.e. run rich during idle... does not rev smmothly.. and when it came on boost, felt as if it leaned out or sumthing... fuel delivery was all wrong basically ... think MAYBE the fuel regulator has something to do with it .... what do u think ??
(note that my fuel reg was tampered with ages ago when we had some fuel problems ... it may have been stuffed up at that time .. who knows ... )
3) i wanna try another fuel reg to see if it is that which is the problem...
do u think is the problem is the fuel reg ?
[Updated on: Tue, 02 November 2004 12:47]
Siktoy ra23
Plumpton/sydney
Re: 1ggte fuel regulator ... gen 3 Tue, 02 November 2004 12:48 Go to previous messageGo to next message
Maybe you should put a fuel guage on it to see if the fuel pressure drops at all
is the car still running a standard ecu ,if so what about your AFM
Les
Re: 1ggte fuel regulator ... gen 3 Tue, 02 November 2004 12:53 Go to previous messageGo to next message
good idea.. should do that..,.,
stabndard ecu also dude.. and afm
Les
Re: 1ggte fuel regulator ... gen 3 Thu, 04 November 2004 05:50 Go to previous messageGo to next message
any good places in sydney that checks fuel pressure etc ?
Re: 1ggte fuel regulator ... gen 3 Thu, 04 November 2004 07:20 Go to previous messageGo to next message
Les wrote on Tue, 02 November 2004 20:45
It will only do that if something is wrong with it.
Les
Re: 1ggte fuel regulator ... gen 3 Thu, 04 November 2004 11:38 Go to previous messageGo to next message
thats why we got the internal pump ... that didnt work...
then external .. that didnt work either !
ahh i dunno whats wrong ..
Re: 1ggte fuel regulator ... gen 3 Thu, 04 November 2004 11:40 Go to previous messageGo to next message
What does that tell you? You're still trying to fix the wrong problem. No No No
Les
Re: 1ggte fuel regulator ... gen 3 Thu, 04 November 2004 13:08 Go to previous messageGo to next message
where to start then mannnnnnnnnn
Re: 1ggte fuel regulator ... gen 3 Thu, 04 November 2004 13:42 Go to previous messageGo to next message
Well, the changing of fuel pumps hasn't fixed the problem, so its obvious its downstream from there. Check the lines, check the filter keep going until you find something wrong.
Les
Re: 1ggte fuel regulator ... gen 3 Thu, 04 November 2004 13:54 Go to previous message
note the internal pump we got was a FEEDER pump, not a replacement for the orig internal RA65 pump hence it had lower flow ... it NEEDS to be used in conjunction with a surge tank i think ... or as a feeder pump to the LARGE external VL pump
phuck .. maybe new lines will do the job .. i think i need to rerun new lines also .. cheaper to start that way
Previous Topic:NEED T50 GEARBOX to suit AE86......... A.S.A.P
Next Topic:cheap shitty rims and tyres
Current Time: Fri Nov 20 16:01:20 UTC 2026
Total time taken to generate the page: 0.0073678493499756 seconds
