Toymods » Tech & Conversions » 5 Speed Conversion (what do I need)
MR 1JZ
5 Speed Conversion (what do I need) Wed, 03 November 2004 05:17 Go to next message
Howdy, upon finding out that a W57 is found in an RA60 celica my plans to convert the soarer to five speed have been brought forward significantly.
Right i would just like to know exactly what i need to convert the 1GGTE to 5 Speed as i might as well start looking for the parts.
I know for sure i need these things:
W57 or W55 (obviously Rolling Eyes)
1G Series Bellhousing
1G Series Clutch (To be modified)
1G Series Flywheel (Can i use one off a more common motor? i.e. 7M?)
Clutch Pedal
Modified Brake Pedal
W57 Slave Cylinder
RA60 Master Cylinder
Get Tailshaft Modified
Right so what else do i need to use and can i use some other parts to maybe keep costs down, if anyone can think of cheaper options for the list I already have please let me know.
Very Happy
ae95
Re: 5 Speed Conversion (what do I need) Wed, 03 November 2004 05:26 Go to previous messageGo to next message
clutch line, may aswell buy a new clutch, pressure plate and bearing.
Re: 5 Speed Conversion (what do I need) Wed, 03 November 2004 05:38 Go to previous messageGo to next message
Use as a rough guide
http://oz-enet.com.au/~peewee/gbox_conv_1.html
Re: 5 Speed Conversion (what do I need) Wed, 03 November 2004 06:39 Go to previous messageGo to next message
MR 1GGTE wrote on Wed, 03 November 2004 15:17
No.
Won't work on a GZ20. You need a master cylinder from a xZ2x Soarer or a xA7x Supra.
MR 1JZ
Re: 5 Speed Conversion (what do I need) Wed, 03 November 2004 06:44 Go to previous messageGo to next message
cruzsida you are the man Very Happy
manythanks
also to you norbie
I am beginning to think that I can actually do this myself Very Happy
How much did it cost to have the front bit of your tailshaft lengthened cruz?
Re: 5 Speed Conversion (what do I need) Wed, 03 November 2004 06:49 Go to previous messageGo to next message
Ummm, $200-$300ish
But he did sometihng wierd to it, like convert it from metric to imperial (sized tubing) because that is all he could get.
So extra machining was done.
Or something like that
Around that figure though
MR 1JZ
Re: 5 Speed Conversion (what do I need) Wed, 03 November 2004 07:08 Go to previous messageGo to next message
hmmm ok, it looks like that might be the most expensive part, oh well, saving $350 on the gearbox is a start i suppose Smile
I am assuming all the hard to get bits can be bought directly from toyota?
Re: 5 Speed Conversion (what do I need) Wed, 03 November 2004 07:24 Go to previous messageGo to next message
MR 1GGTE wrote on Wed, 03 November 2004 15:08
Yeah, when you trade in your first born.
Best bet is to find a Manual xA70.
That will have all the lines,cyls,pedals.
MR 1JZ
Re: 5 Speed Conversion (what do I need) Wed, 03 November 2004 07:31 Go to previous messageGo to next message
CrUZsida wrote on Wed, 03 November 2004 17:54
Im not worried about the pedals and shit they are easy to come by its more the flywheel, spigot bearing, thrust bearing, clutch that could be uber hard to find, having a mate in spare parts helps as i get trade and staff discount, my last timing belt only cost me $32 Very Happy
Re: 5 Speed Conversion (what do I need) Wed, 03 November 2004 07:33 Go to previous messageGo to next message
MR 1GGTE wrote on Wed, 03 November 2004 15:31
Flywheel shouldn't be too hard
Spigot bearing can be gotten anywhere for $5
Thrust bearing should come with a clutch kit.
Dont get a clutch until you have the flywheel, and then take it somewhere and get them to match a decent clutch to it (ie 800kg+)
So do it already
YelloRolla
On your mum!
Re: 5 Speed Conversion (what do I need) Wed, 03 November 2004 07:42 Go to previous messageGo to next message
Flywheel from a 3T GTE can fit - I think that it does take a clutch plate that is 1/4" smaller in diameter than some 1G's.
Incidentally I have a brand new 9 1/4" Exedy Daikin HD pressure plate up for grabs.
PM me for details (I also have a bell housing for 1G).
edit/I can organise having the clutch fitted to a flywheel (one of which can be sourced from a T18 and be modified to suit the pressure plate.
[Updated on: Wed, 03 November 2004 07:44]
MR 1JZ
Re: 5 Speed Conversion (what do I need) Wed, 03 November 2004 07:47 Go to previous messageGo to next message
CrUZsida wrote on Wed, 03 November 2004 18:03
So do it already
I will I will but not untill i get back form melbourne becuase i have decided to do it myself so i might as well start it after a road trip incase i fux0rs it up i have some more time up my sleeves, as greasy as they will be Smile
MR 1JZ
Re: 5 Speed Conversion (what do I need) Wed, 03 November 2004 07:51 Go to previous message
YelloRolla wrote on Wed, 03 November 2004 18:12
you have PM Regarding this matter
Very Happy
Previous Topic:WNTD Supercharged K series info?
Next Topic:18RGEU
Current Time: Fri Oct 16 00:06:16 UTC 2026
Total time taken to generate the page: 0.094876050949097 seconds
