Toymods » Tech & Conversions » Help needed smoke from my exhaust
JZA-07T
icon9.gif  Help needed smoke from my exhaust Wed, 03 November 2004 05:40 Go to next message
Hey guys i hope you can help me i just replaced one of my blown turbos (C12A) from my 1jz and my exhaust is blowning out alot of white smoke and theyu also told me that the exhaust side of the turbos the fins snpped off and destroyed my cat in my exhaust...would that be the problem... please help....
Re: Help needed smoke from my exhaust Wed, 03 November 2004 06:36 Go to previous messageGo to next message
More information needed. Is the smoke white or blue-ish? When does it smoke (after starting/on boost/all the time)? Are there any other symptoms (eg poor idle, running rough)?
A busted/clogged cat won't cause smoke.
JZA-07T
Re: Help needed smoke from my exhaust Wed, 03 November 2004 22:17 Go to previous messageGo to next message
Thanks for your reply... its white smoke and happens after i drive the car for a bit and when it sits and idles it starts to come out with smoke...aned it runs well no idle prob or lack in performance....
Toobs
Re: Help needed smoke from my exhaust Wed, 03 November 2004 22:32 Go to previous messageGo to next message
Its either turbo seals or valve stem seals.
Probably a good idea to rebuild your second turbo anyway seeing as you have already rebuilt the other one (or buy a nice single turbo).
Spanktown
Inside a giant turbo (syd...
Re: Help needed smoke from my exhaust Wed, 03 November 2004 23:12 Go to previous messageGo to next message
if it was turbo seals, wouldnt it blow black smoke? sounds more like stem seals
Toobs
Re: Help needed smoke from my exhaust Wed, 03 November 2004 23:30 Go to previous messageGo to next message
Spanktown wrote on Thu, 04 November 2004 10:12
Nope if you have stuffed turbo seals you will blow white smoke.
Black smoke is usually overfueling.
Re: Help needed smoke from my exhaust Thu, 04 November 2004 00:30 Go to previous messageGo to next message
Burning oil means blue-white smoke; doesn't matter if it comes from stem seals or turbo seals.
lumpy
Adelaide, SA
Re: Help needed smoke from my exhaust Thu, 04 November 2004 01:29 Go to previous messageGo to next message
I'd check the PCV valve setup (on the intake side especially) - these can clog and over-pressurise, pumping oil into the intake at idle. It tends to be an intermittant problem but can pour out the smoke when idling for a long time (eg at the Maccas drive-thru!).
4agte
Toronto, Downtown
Re: Help needed smoke from my exhaust Thu, 04 November 2004 04:48 Go to previous message
blown head gaskets can also blow white smoke.
Previous Topic:4agze injector serice kit toyota P/N.
Next Topic:is a bigport dizzy interchangable with a smallport dizzy?
Current Time: Sat Nov 21 02:07:28 UTC 2026
Total time taken to generate the page: 0.017235040664673 seconds
