Toymods » Tech & Conversions » Mk2 7mgte Project
sprinter_86
Mk2 7mgte Project Wed, 03 November 2004 07:37 Go to next message
Can someone tell me wat mods they had to make in this conversion like wat did they do with the sump and the oil filter thats in the way of the engine mounts. and anything else they had to make fit thanks.
Re: Mk2 7mgte Project Wed, 03 November 2004 07:45 Go to previous messageGo to next message
Bolts in
Use 5me/5mge sump, oil pickup, mounts
STR8 2.8
Re: Mk2 7mgte Project Wed, 03 November 2004 07:46 Go to previous messageGo to next message
check the faq's at http://www.celicasupra.com
Pure_In_Sanity
Melbourne, Vic
Re: Mk2 7mgte Project Wed, 03 November 2004 07:51 Go to previous messageGo to next message
I am doing the same conversion in my mk2 however i am doing brakes / suspension upgrades first. I think you can even use the 4m / 2m sump and pickup.
If space is tight you can use a remote oil filter setup.
Cooling system should be a point of attention, a bigger radiator may be needed.
Intercooler may be hard to fit if you are running A/C
W58 5speed gearbox can be used but custom mount may be required.
Good Luck
-Phil
Re: Mk2 7mgte Project Wed, 03 November 2004 07:54 Go to previous messageGo to next message
Cooling system *should* be ok, if the radiator is clean
You don't need a custom mount for the w58.
STR8 2.8
Re: Mk2 7mgte Project Wed, 03 November 2004 08:03 Go to previous messageGo to next message
hmm perhaps you should clarify what car it is...
i saw mk2 and assumed you meant mk2 supra but i could be wrong Confused
sprinter_86
Re: Mk2 7mgte Project Wed, 03 November 2004 08:24 Go to previous messageGo to next message
yea its an 85 celica supra also do you need the air flow metre off the 7mgte if your using an aftermarket computer and will the 5me one work if no.
Re: Mk2 7mgte Project Wed, 03 November 2004 08:29 Go to previous messageGo to next message
If you are using and after market ecu, then you wont need any airflo meter as they all use MAP
90% of the 5me stuff will be useless
Pure_In_Sanity
Melbourne, Vic
Re: Mk2 7mgte Project Wed, 03 November 2004 09:17 Go to previous messageGo to next message
Yep, Me wrong Laughing
i assumed u meant mk2 corona....
Cool My Bad!
-Phil
Re: Mk2 7mgte Project Wed, 03 November 2004 19:53 Go to previous messageGo to next message
No, they are wrong.
You actually own a Toyota Mark2.
Vote 1 "Mark" is most overused term (after JDM) on Japanese car forums. Rolling Eyes
STR8 2.8
Re: Mk2 7mgte Project Thu, 04 November 2004 00:53 Go to previous messageGo to next message
gianttomato wrote on Thu, 04 November 2004 06:53
No, they are wrong.
i second that
it is a celica supra! i think yanks are the worst offenders, its all mk2, mk3, mk4 to them ugh
Pure_In_Sanity
Melbourne, Vic
Re: Mk2 7mgte Project Thu, 04 November 2004 06:31 Go to previous messageGo to next message
Yeah i'll 3rd it! lol Very Happy
I guess Toyota couldnt make up their mind when they called it a Celica Supra. Was it actually called that here in Aus? - or just a supra?
Sorry to drift off the subject...
Hope the conversion goes well Cool
-Phil
sprinter_86
Re: Mk2 7mgte Project Thu, 04 November 2004 07:13 Go to previous messageGo to next message
Yea should have just put ma61 Razz. The conversions goin well so far picked up my 7mgte wed and have changed the sump over from the 5me moved the oil pick up and moved the oil filter to so engine mounts will fit and moved the dip stick 5me was all out today and 7m should be in tomorow.
Pure_In_Sanity
Melbourne, Vic
Re: Mk2 7mgte Project Thu, 04 November 2004 07:28 Go to previous messageGo to next message
Sweet!
May i ask how much the 1/2 cut set u back + where you got it from? Not many places seem to have them instock at the moment. From what i gather, 'Rolin' may be the best place to get one from. Ive been quoted $2500 - $3200 so far (5spd)
sprinter_86
Re: Mk2 7mgte Project Thu, 04 November 2004 08:48 Go to previous messageGo to next message
I bought just the engine for $1400 was from asian auto spares slacks creek, brisbane, yea im sure u can get a half cut for $2500.
Pure_In_Sanity
Melbourne, Vic
Re: Mk2 7mgte Project Thu, 04 November 2004 09:43 Go to previous messageGo to next message
Thanks, i've seen their add a few times in Zoom. Will further investigate Surprised
-Phil
negative boost
Hobart, TAS
Re: Mk2 7mgte Project Thu, 04 November 2004 10:22 Go to previous messageGo to next message
Hey PIS, i emailed these guys not long ago and this is wat they said
Jap performance - None in stock atm but try in december $2500, auto
Rolin - None in stock but usually $3300
Adeliade Jap - Package only in stock atm $1950
CVAP - $2500, auto
All Auto Imports - Package only in stock $2300
I emailed others but they either didn't reply or didn't have any in stock and wernt going to import more.
sprinter_86
Re: Mk2 7mgte Project Thu, 04 November 2004 11:37 Go to previous message
When do these engines redline?
Previous Topic:Drum to disc rear conversion costs?
Next Topic:What would I need to change if I put a 7MGTE in a GA70?
Current Time: Tue Nov 24 08:43:29 UTC 2026
Total time taken to generate the page: 0.0065069198608398 seconds
