Toymods » Tech & Conversions » fuel pumps turning themselfs on
ta2272
fuel pumps turning themselfs on Wed, 03 November 2004 13:37 Go to next message
My fuel pumps are turned on when ingintion is turned on , through a realay,sometimes i will leave my car and one minute later the pump will turn on?
Is it just a buggerd relay, is a 30amp relay big enought for two fuel pumps (vl fuel pump and small pusher pump)
Jason
Re: fuel pumps turning themselfs on Wed, 03 November 2004 22:00 Go to previous messageGo to next message
that depends on the quality of the relay.. a lot of the "30A horn relays" are not rated for 30A continuous..
it would be safer to plug in another relay anyway, and get a decent one (ie Bosch, potter&brumfield etc)
ra23celica
Re: fuel pumps turning themselfs on Thu, 04 November 2004 01:28 Go to previous messageGo to next message
I have the reverse problem, getting the bloody fuel pump to switch on, traced to (wait for it !) a bad earth. Your relay is buggered as Stewart said, get a heavy duty unit or pinch one from Nick a Part out of an old EFI Cressida.
[Updated on: Thu, 04 November 2004 01:29]
Re: fuel pumps turning themselfs on Thu, 04 November 2004 01:35 Go to previous messageGo to next message
fwiw, i'm currently rewiring my entire car, and for most things, i will be earthing direct to the battery, thru a series of large earth cables... like the 25 and 60 amp cables (12/8gauge?) from Jaycar.
nothing i hate more than bad earths Wink
for relays, the VL commondores seem to have good quality ones. other than that i prefer to use 'proper' potter&brunfield ones, where the 40A rating is continuous, not 'horn' intermittent.. they cost between $5 and $10 each usually.
ra23celica
Re: fuel pumps turning themselfs on Thu, 04 November 2004 02:03 Go to previous messageGo to next message
Damn funny you should say exactly this as I have an external fuel pump for my 1G-GZE in my RA23. It was earthed inside the cabin and then that failed. So I ran a twin thick earth cable from an old Corolla battery earth from the fuel pump to one of its chassis mounting bolts and also across to a bolt that runs into the chassis rail. Worked fine for 3 mins and then gradually the fuel pump slowed down to a complete stop. Now I have a dicky little 2mm wire running from the pump underneath the chassis all the way back to the battery - and of course - it works fine.......<sigh>....
sideshow
Re: fuel pumps turning themselfs on Thu, 04 November 2004 03:12 Go to previous messageGo to next message
dont use relays from any holden
they are wired differently to your normal bosch relay
unless you know what you are doin
bosch relays and holders will set you back about 15 bucks for the set
goto your local auto elctrician and get them
most auto parts shops sell the cheaper relays
hella make ok relays too
Re: fuel pumps turning themselfs on Thu, 04 November 2004 03:36 Go to previous messageGo to next message
thats weird...
the ones i got were from a VL commonwhore. they have detachable bases that clip onto the sides of the 'relay box'. the relays themselves were Bosch branded, and were the normal 85/86, 30/87 type. there was also a metal one which had the 87a terminal also...
i redid the wiring using clip secured spade terminals from Dick Smith (at $4.85 for 10 Sad ), and it all seems to work normally...
Sideshow, which are the weird Holden relays??
ps
http://www.materials.unsw.edu.au/~sford/relays1.jpg
[Updated on: Thu, 04 November 2004 03:38]
sideshow
Re: fuel pumps turning themselfs on Thu, 04 November 2004 04:07 Go to previous messageGo to next message
holdens have 2 pins in wrong spot
u can use them but mainly holdens use this pin layout
most other relays have 85 and 86 across
then 30 and 87 up and down
holdens dont
they look exactly the same but the pin outs are different
last number on relay i think on holdens is 457
normal bosch relay is 150
those clips i buy 100 for under 10 bucks hehe
the holdens one have 85 86 diagonally
and 30 87 diagonally too
[Updated on: Thu, 04 November 2004 04:10]
Re: fuel pumps turning themselfs on Thu, 04 November 2004 05:14 Go to previous messageGo to next message
ahhh, gotcha, i didn't even think about it Wink i just wired up by numbers Very Happy
ahh well, easy enough to push the pins from relay base if i ever need to change Wink
sideshow
Re: fuel pumps turning themselfs on Thu, 04 November 2004 06:02 Go to previous message
yes
but thats y i never use holden relays on other cars but holdens
if u put a holden relay in a socket setup for normal relays u blow things up
its mainly the people who dont know the difference
a relay stuffs up in their holden and they goto local shop and buy a normal one and they wonder why theres a funny smell in the car
[Updated on: Thu, 04 November 2004 06:25]
Previous Topic:brakes without booster
Next Topic:relay/fuse thingy...and who says ford/holden have nothing to contribute..
Current Time: Sat Nov 21 03:51:43 UTC 2026
Total time taken to generate the page: 0.0063281059265137 seconds
