Toymods » Tech & Conversions » Bad shudder pulling away in my auto 1G
Lee J
Bad shudder pulling away in my auto 1G Wed, 03 November 2004 13:57 Go to next message
I have just had my first drive of my TA22 having put my 1G GTE back in. I balanced the prop, replaced some of the UJ bearings, replaced the centre bearing and replaced the broken auto gearbox mount. The engine mounts seem OK. I was hoping to cure a horrible shudder I get when I pull away. To my suprise NO BLOODY IMPROVEMENT! If I pull away anything other than extremly slowly it vibrates low frequency (moving the gearshift about) until I pick up a bit of speed. it's Ok on the move.
Could it be rear bushes? How do I tell if they are OK? Could it be diff oil? What should it be? Could it be the auto tranny?
Anyone any ideas?
Help appreciated from a Pomme far from home
indian
south east - melbourne
Re: Bad shudder pulling away in my auto 1G Wed, 03 November 2004 23:09 Go to previous messageGo to next message
god man i think my 1g does that too around 80ks when the cars is cold it shudders u can feel slightly thorught the steering but once its warm cant notice at all and at faster speed sthe cars doesnt shudder at all funny
could be the tranny
cthulhu
Re: Bad shudder pulling away in my auto 1G Thu, 04 November 2004 00:00 Go to previous messageGo to next message
mine does that too i thought id need my wheels balanced or something
soaringmik
Re: Bad shudder pulling away in my auto 1G Thu, 04 November 2004 00:39 Go to previous messageGo to next message
Scrap that,.. Embarassed
[Updated on: Thu, 04 November 2004 00:39]
Re: Bad shudder pulling away in my auto 1G Thu, 04 November 2004 03:41 Go to previous messageGo to next message
Lee J wrote on Wed, 03 November 2004 21:57
When you say, "I balanced the tailshaft", does that mean you personally did it? or you gave it to a professional?
If you personally did it, I would take it somewhere and get it done professionally.
It will be the most likely cause of this.
Other than that it could be a slipping clutch, or badly balanced flywheel.
Re: Bad shudder pulling away in my auto 1G Thu, 04 November 2004 03:51 Go to previous messageGo to next message
This can happen when you have too much angle on one of the uni joints. Check if your centre bearing is in upside down, I did this once and got the shuddering you describe.
Mookie
Tassie
Re: Bad shudder pulling away in my auto 1G Thu, 04 November 2004 03:57 Go to previous messageGo to next message
It wouldn't be the belts in ur tranny would it ?
This has happened with the sigma my mum had a while ago.
Like under heavy load (read= Foot flat) It would shudder really badly like something was slipping . We got the belts tightened in the gearbox and it never did it again . when was the last time ur gearbox was serviced ?
[Updated on: Thu, 04 November 2004 03:57]
Lee J
Re: Bad shudder pulling away in my auto 1G Thu, 04 November 2004 08:07 Go to previous messageGo to next message
Centre bearing...is there a front or back, upside down etc? I tried to align it with the rubber parting line slightly to the rear (I think the part is from a Hilux).
Balanced prop - supposedly done professionally but I don't have much faith in some of the work here (Malaysia).
Transmission - I don't know if it has ever been serviced? I changed the oil recently. It didn't make a differnce.
I have checked out the bushes at the rear and some are definetly dodgy - is this enough to cause the bad shudder?
Anyone know the size of the 10 bushes so I can buy before dismantling?
cheers fellas,
Siktoy ra23
Plumpton/sydney
Re: Bad shudder pulling away in my auto 1G Thu, 04 November 2004 09:40 Go to previous messageGo to next message
How about your axels are they bent?
YelloRolla
On your mum!
Re: Bad shudder pulling away in my auto 1G Thu, 04 November 2004 09:59 Go to previous messageGo to next message
Sounds to me like either the converter is stuffededded or the bands in the tranny.
My money rests with the converter.
Lee J
Re: Bad shudder pulling away in my auto 1G Thu, 04 November 2004 10:14 Go to previous messageGo to next message
OK. I know I need to redo my bushes but I am interested in checking out the tranny. How do I check to see if the torque convertor is on it's way out or if the bands are loose? It is OK once I get going but the gear changes are pretty slow.
I wanted to put a manual in anyway!
YelloRolla
On your mum!
Re: Bad shudder pulling away in my auto 1G Thu, 04 November 2004 10:35 Go to previous messageGo to next message
Lee J wrote on Thu, 04 November 2004 21:14
OK.
Prollem solved
Rattlehead
Re: Bad shudder pulling away in my auto 1G Thu, 04 November 2004 10:38 Go to previous messageGo to next message
What was it?
I got that in my 1G. After 80 ks. I got the thing serviced with the bands adjusted and stuff and it helped quite a bit but still does it. I think the tranny is just stuffed...coz it was getting worse as I put on the k's.
Lee J
Re: Bad shudder pulling away in my auto 1G Thu, 04 November 2004 14:03 Go to previous messageGo to next message
I think Norbie was right, it looks like the centre bearing was upside down (I didn't fit it!!). Haven't tested it yet though as the captive nut is knackered - needs a bit more messing. The prop is more or less in line with the tranny now so I have high hopes.
cheers.
celicamad
newcastle
Re: Bad shudder pulling away in my auto 1G Fri, 05 November 2004 10:34 Go to previous messageGo to next message
althouhg the centre bearing is MOST likely the problem . in the 1j auto i had trasmission shudder when using dextron III . i switched to toyota type IV and ....fixed it i read it on soarer forums and thought ,,,what harm can it do
Just an idea
SIKPUPY
Re: Bad shudder pulling away in my auto 1G Sat, 18 December 2004 06:25 Go to previous messageGo to next message
anyone need an auto for their 1g
came of a 1ggze, 96000 k's going cheap otherwise Im going to strip it and send it to the scrap metal people
Am in Perth
Re: Bad shudder pulling away in my auto 1G Sat, 18 December 2004 07:21 Go to previous message
SIKPUPY wrote on Sat, 18 December 2004 14:25
Am in Perth
Dude, there is a for sale section for things like this.
Previous Topic:TE71 levin rear disks
Next Topic:Front speakers AE82
Current Time: Sat Nov 21 00:13:09 UTC 2026
Total time taken to generate the page: 0.0077240467071533 seconds
