Toymods » Tech & Conversions » Possible group buy: adjustable camber/castor tops?
wagonist
Toymods Club Treasurer
icon5.gif  Possible group buy: adjustable camber/castor tops? Thu, 04 November 2004 01:00 Go to next message
Can peeps please tell where adjustable camber tops might be bought from?
I then want to find out how hard it would be to turn them through 90 degrees to allow for castor adjustment instead.
Or does someone already make these off the shelf?
enough castor is something that is generally lacking in Toyotas from what I've seen.
Also, how many different strut top plates does Toyota make?
My Caldina has 3 bolt in an isosoles(?) triangle setup.
ChuckLandwehr
Re: Possible group buy: adjustable camber/castor tops? Thu, 04 November 2004 05:30 Go to previous messageGo to next message
Wagonist, K-Mac actually make quite a few castor/camber adjusting kits. They are available for TA22/RA23, so you might be in luck. I am about to remove a set from a 23, so PM me the distance between the studs, and I will see if they are the same. Oh yeah my lad has a set for a TA22 sitting in the workshop, I can also check measurements against them.
regards Chuck.
indigoid
Canberra, ACT
Re: Possible group buy: adjustable camber/castor tops? Thu, 04 November 2004 07:26 Go to previous message
general opinion I've seen is that the K-mac ones are crap and the Noltec ones are alright.. in the context of both RWD Volvos and RWD Corollas
I hope to get some KE2x Noltec tops soon. $440 according to their site
Previous Topic:Camber top washers
Next Topic:Braking issues - SOLVED...loose line :P
Current Time: Sat Nov 21 05:01:35 UTC 2026
Total time taken to generate the page: 0.0043928623199463 seconds
