Toymods » Tech & Conversions » 2JZ-GTE in AE...
ycbh
Toronto, ON, Canada
2JZ-GTE in AE... Thu, 04 November 2004 04:57 Go to next message
I own a 1982 Rolla Coupe AE71 same chassis/suspension as AE86 and looking to make a sleeper looking to install a 2JZ-GTE. If u know any info about this conversion please let me know i would appreciate any help in this matter u can email me or reply me on this post. I live up-above or as u guys like to say to us down-under in canada and have no restrictions on type of motor in any car i already have a fast honda civic but wanna go fast in my yota. hondas are too played out in canada and usa wanna smoke some serious honda ass LOL...HELP AUSSIES HELP
Sprinter-Saurus
Re: 2JZ-GTE in AE... Thu, 04 November 2004 05:06 Go to previous messageGo to next message
yeah you could do it, theres a few AE86's in Japan that i know of with this conversion done, but dont expect it to be cheap, fabrication to make it fit will be exspensive. Razz
if you go through with it make sure you post up pics when its done. Very Happy
Re: 2JZ-GTE in AE... Thu, 04 November 2004 06:26 Go to previous messageGo to next message
JZ engines are about 3 times the length of an AE71 engine bay. OK not quite but you get the point - major structural modifications are required before the engine can even be bolted in. Those 2JZ powered AE86's in Japan are full-house drag cars, and I doubt they'd be much good for anything else.
If you just want to beat Honda's, there are far easier ways of doing it. A well-tuned 4A-GTE should be enough to dispatch almost any Honda.
EMP-2TG
Carlingford, Sydney
Re: 2JZ-GTE in AE... Thu, 04 November 2004 06:32 Go to previous messageGo to next message
have you seen how much the firewall is cut on the c$ y sports corolla? heaps! haha
i only know of 1 corolla over there and 1 over here in aus
4agte is the way to go
Re: 2JZ-GTE in AE... Thu, 04 November 2004 07:05 Go to previous messageGo to next message
did you read what i wrote over at twincam.org dude? Its not a viable option unless you want to in a straight line, and have a spare CAD$15000 up your sleeve......
1g-gte, 4agte, 3sgte are all much more viable options, which will fit without coming halfway out your dash, and without tearing the nose off the car. Heck you could even still turn corners with those motors Razz
ae95
Re: 2JZ-GTE in AE... Thu, 04 November 2004 07:07 Go to previous messageGo to next message
Could even do a ca18det or sr20det if you wanted
YelloRolla
On your mum!
Re: 2JZ-GTE in AE... Thu, 04 November 2004 10:32 Go to previous messageGo to next message
you fu*kers are boring. Rip into it!
You will need - Sheet metal (0.8mm ).9 and 1.0mm zinc anneal would be my choice)
Oxy Acetylene
Mig and or Tig welder (I like to have both by my side)
4" grinder and 9" grinder c/w cut off discs and grinding pads
Mill and Lathe and various tools for operating both machines
Safety glasses (duh)
Swaging machine
$2000 budget for Earl's fittings
An engine will help (in this case a 2JZ GTE will be perfect and it will keep with the original theme).
Custom tailshaft
You could try the JDM LSD but a 9" will be more appropriate.
A roll cage is also a good idea (but it will detract from the sleeper image unless it is done well).
Prolly custom pedal box and associated master cylinders
Custom front Struts (Lamb are a good brand)
Box the control arms
Wilwood brakes all around (or equivalent)
examine your head (you may be abe to afford to have someone else examine it)
Get a big ass Turbo and some big ass bollocks
Front mount intercooler
Account with Capral aluminium (or Canadian equivalent)
Safety gloves, safety boots, safety first.
Welding helmet, shitload of spare time
20PSI should do while tuning/running it in and then you can get serious with the boost add a double or triple (phwoar) NOS before cruising Ontario's main boulevardes.
Now as long as you have these and the ability to make various jigs, SST or WST's along the way, then you should get out into that ga rage and make it happen. Post some pics along the way.
Good Luck and take NIL crap from that other bunch of heartless pricks.
Roll on the JZE71 - has a nice ring to it.
Re: 2JZ-GTE in AE... Thu, 04 November 2004 10:50 Go to previous messageGo to next message
nahh, triple turbo 20B.. no point stopping at 3L Wink may as well have a crack at 1000hp while you are cutting the front of the car Wink
seriously tho, it can't be that hard to fit the J. if it's too long, just use two smaller radiators split to either side of the motor.. easy Wink
heck you could even bonnet mount the radiators to either side of the bonnet with a nice big fan on each pokng thru Very Happy would look... interesting....
good luck and take lotsa pics Wink
YelloRolla
On your mum!
Re: 2JZ-GTE in AE... Thu, 04 November 2004 11:11 Go to previous messageGo to next message
Rapid8 commodore has radiator in the boot and thermo fans exit through bootlid.
..J..
opening a can of whoop ass
Re: 2JZ-GTE in AE... Fri, 05 November 2004 01:19 Go to previous messageGo to next message
YelloRolla wrote on Thu, 04 November 2004 21:32
Oxy Acetylene
Swaging machine
Custom tailshaft
WERD
rob_RA40
c'town, NSW
Re: 2JZ-GTE in AE... Fri, 05 November 2004 01:21 Go to previous messageGo to next message
Oxy Acetylene
Swaging machine
Custom tailshaft
dont forget the beer, lots and lots of beer Very Happy
Skip
Re: 2JZ-GTE in AE... Fri, 05 November 2004 01:35 Go to previous messageGo to next message
YelloRolla wrote on Thu, 04 November 2004 18:32
Oxy Acetylene
Swaging machine
Custom tailshaft
and marriage councillor perhaps...
MR 1JZ
Re: 2JZ-GTE in AE... Fri, 05 November 2004 01:44 Go to previous message
YelloRolla wrote on Thu, 04 November 2004 21:02
Oxy Acetylene
Swaging machine
Custom tailshaft
The man has spoken, now get cracking on it! Nod
hey if you got the cash seriously do it, if i had the cash id squeeze one into a KE20 hehehe
Previous Topic:JDM ECU into 3sge gen 1
Next Topic:Ta23 front window
Current Time: Sat Nov 21 04:56:38 UTC 2026
Total time taken to generate the page: 0.006187915802002 seconds
