Toymods » Tech & Conversions » Is 4age 16v 100kw loom compatible with 88kw engine?
Choony_AE86
Melbourne, South East
Is 4age 16v 100kw loom compatible with 88kw engine? Thu, 04 November 2004 05:25 Go to next message
Does anyone know if the 100kw 4age smallport loom works with the 88kw bigport engine?
im planning to put this 4age into my sprinter, and got a 100kw loom i might buy for pretty cheap soon.
Has anyone used the 100kw on the 88kw engine?
Any feedback will help
Choony
Re: Is 4age 16v 100kw loom compatible with 88kw engine? Thu, 04 November 2004 05:37 Go to previous messageGo to next message
Not an easy fit.. What ECU are you using? The 88 and 100kw ECU plugs are different so this question kinda depends on the ECU.
But even so, you got problems then with TVIS, ignitor is different, coil arrangement is different..
Bigport looms are easy to come by, I have one for sale now for $100 and its yours. Be much easier than trying to adapt a 100kw one.
Joel
Choony_AE86
Re: Is 4age 16v 100kw loom compatible with 88kw engine? Thu, 04 November 2004 05:53 Go to previous messageGo to next message
im gonna be running an 88kw ecu..
but i havent found an 88kw loom around or on the forums
but it seems that u've fixed dat problem Very Happy
PM sent
Re: Is 4age 16v 100kw loom compatible with 88kw engine? Thu, 04 November 2004 06:05 Go to previous messageGo to next message
If using 88kw ecu then your only option is to use 88kw loom. As mentioned the plugs are different.
Joel
shinybluesteel
melbourne
Re: Is 4age 16v 100kw loom compatible with 88kw engine? Fri, 05 November 2004 00:20 Go to previous message
not wanting to intrude, but i have a bigport ECU and loom that i dont need also, the loom is cut to some extent (it came out of a sprinter) and doesn't have an igniter.
i'm interested in who is selling the 100kw loom, as i have two of these already and seem to be collecting them Rolling Eyes . mainly interested if it comes with an igniter.
[Updated on: Fri, 05 November 2004 00:22]
Previous Topic:Ta23 front window
Next Topic:3sgte gearbox
Current Time: Sat Nov 21 04:22:47 UTC 2026
Total time taken to generate the page: 0.0053610801696777 seconds
