Toymods » Tech & Conversions » 4AGE harmonic balancer bolt torque spec, anyone?
macks
4AGE harmonic balancer bolt torque spec, anyone? Sun, 06 October 2002 09:41 Go to next message
The toyota 4AGE book says 101ft lb, which is frickin tight (yes toit .. toit loik a toiga Razz ) but that broke the last bolt and I don't want to wait a week for another one, again. Sad
Is 101ftlb a misprint, or...? It doesn't look like it needs to be too tight, as everything attatched to it fits in a groove on the crank, so it's not holding anything on by clamping force, just keeping it on the end of the crank. Any ideas what it should be torqued to?
cheers!
BigWorm
Toymods Board Member
Turramurra, Sydney.
Re: 4AGE harmonic balancer bolt torque spec, anyone? Sun, 06 October 2002 10:04 Go to previous messageGo to next message
My Haynes corrola manual has the same torque spec.
I just did mine up bloody tight, I have no torque wrench.
macks
Re: 4AGE harmonic balancer bolt torque spec, anyone? Sun, 06 October 2002 11:56 Go to previous messageGo to next message
cheers, I may just do the same (101 ft lbs is frickin tight)
TE72_Turbo
Re: 4AGE harmonic balancer bolt torque spec, anyone? Sun, 06 October 2002 13:14 Go to previous message
actually, the keyway on the crank is only there to locate the harmonic balancer, not to handle any stress. If you do not have sufficient torque on the balancer bolt, the balancer itself can rotate slightly and slam against the keyway, eventually breaking it.
Its a big bolt, and should handle 100lb/ft no worries. If you broke it, then either your torque wrench is wrong, or the bolt was fatigued, or had insufficient lubrication on the threads.
Good luck Very Happy
Previous Topic:Timing belt slipped at above 6000rpm??
Next Topic:sump gasket
Current Time: Sat Nov 21 10:58:13 UTC 2026
Total time taken to generate the page: 0.014212131500244 seconds
