Toymods » Tech & Conversions » ke70 cable clutch installation?
Big T
ke70 cable clutch installation? Thu, 04 November 2004 13:33 Go to next message
sorry if i seem like a dumbass but we all gotta start somewhere right? Confused currently, me and a mate have just installed the
gearbox but i cant figure out how the cable clutch hooks up. i know the end has to hook onto the release lever sticking out of the
clutch housing but exactly how this is done i cant figure out. i read the cable has to slot through a hole in the bellhousing but
which hole is this refering to? i also think im missing a couple bits off the end of the cable so if anyone could even just post a
piccy, it would be really helpful. i bought the ke with the box out of the car so i dont know what it looked like already installed.
cheers.
eddie.
[Updated on: Thu, 04 November 2004 13:45]
Re: ke70 cable clutch installation? Thu, 04 November 2004 13:59 Go to previous messageGo to next message
a gregory's manual will be a huge help for you Smile
good luck,
Big T
Re: ke70 cable clutch installation? Fri, 05 November 2004 07:37 Go to previous messageGo to next message
i actually already bought the gregorys manual but it assumes that the clutch is already installed and you're adjusting it. it just
says to take note of where all the stuff is bolted on so you can put it back into the original placings. but like i said... the clutch and
box weren't in the car so i never got to see where everything was placed.
eddie
alex_ta22
Newcastle, Hunter Valley
Re: ke70 cable clutch installation? Fri, 05 November 2004 10:30 Go to previous messageGo to next message
thats what i was gonna send you, look harder on page 73.
to install basically all you have to do is:
1.slip the clutch end of the cable through the bellhousing (the hole that lines up with the release lever)
2.bolt the cable support on
3.Put the "E" clip on ( before the bellhousing, engine side)
4.slide thogh firewall
5.Slip over clutch pedal ( notch on the top of it)
6.Place the second "E" clip in
PS. On the gearbox end of the cable, there is a removable part, the "clevis", that is most probably the part that is missing as it just slips off the end of the cable
Big T
Re: ke70 cable clutch installation? Fri, 05 November 2004 22:58 Go to previous messageGo to next message
ah ok... told ya i was a dumbass Laughing i can do all this with the box/bellhousing bolted onto the engine cant i? everythings already bolted in, including the xmember.
alex_ta22
Re: ke70 cable clutch installation? Sat, 06 November 2004 06:02 Go to previous message
yeah, having the gearbox in does tend to make the job easier Very Happy
Previous Topic:1UZFE engine dimensions ?
Next Topic:1ggte iradum vs platinum adn plug gap when increasing boost
Current Time: Thu Nov 19 10:24:26 UTC 2026
Total time taken to generate the page: 0.0069239139556885 seconds
