Classifieds » Parts Wanted » Speedo gear from RA65 @55 gearbox please
Les
Speedo gear from RA65 @55 gearbox please Thu, 04 November 2004 13:52 Go to next message
If anyone has a gearbox from an RA65 celica ... a W55 with F372 axle ... will u part with the speedo gear
Les
wilbo666
Re: Speedo gear from RA65 @55 gearbox please Fri, 05 November 2004 00:43 Go to previous messageGo to next message
I thought that the RA65's had W57's or W58's? (I'm guessing your going off the plate tho?!)
Also if you do a search for something like speedo gears or something there is some good info. I remember a listing of teeth numbers and what gearbox/diff ratio they came out with. Might be easier to ask for a specific number of teeth on the gear you want Smile
(also the fact that there are two different internal gears that mesh with external gear you want might effect you, I'm not sure what your plans are...?).
Also pretty sure you can get them from toyota as well for around $30? if it comes to that Smile
Les
Re: Speedo gear from RA65 @55 gearbox please Fri, 05 November 2004 00:47 Go to previous messageGo to next message
yeah man, im goin off the plate Smiley =
well basically i got a w5x from a gx81 and it has stuffed up my speedo reading .. originally a 255 with F372 axle .. so i guess i need to get the original speedo gear to plug back into the new box.. is that not right ?
$30 from toyota what the !!?? let me give them a call
wilbo666
Re: Speedo gear from RA65 @55 gearbox please Fri, 05 November 2004 01:38 Go to previous messageGo to next message
Might be an idea to check that you have the same number of teeth on the gear in your new gearbox as you did in your old! (there is a gear on the output shaft that drives the nylon gear, and there are two different types, they have a different number of teeth, 10 vs 11 I think, this will also effect your speedo).
http://forums.toymods.org.au/index.php?t=msg&t h=21974&rid=36&S=b33fff4de0cd3f4b6cd011c66 99aeb4e&pl_view=&start=0#msg_182507
http://forums.toymods.org.au/index.php?t=msg&t h=16706&rid=36&S=b33fff4de0cd3f4b6cd011c66 99aeb4e&pl_view=&start=0#msg_135998
http://forums.toymods.org.au/index.php?t=msg&t h=24901&rid=36&S=b33fff4de0cd3f4b6cd011c66 99aeb4e&pl_view=&start=0#msg_213093
The links might be of help (oh and it might be closer to $60 looking back Embarassed )
Les
Re: Speedo gear from RA65 @55 gearbox please Fri, 11 February 2005 11:33 Go to previous message
im just gonna fucken pay someone to do this ...
Previous Topic:7mge supra manual bellhousing
Next Topic:WTB 7afe
Current Time: Sat Oct 17 03:01:32 UTC 2026
Total time taken to generate the page: 0.0055000782012939 seconds
