Toymods » Tech & Conversions » 4AGE 100kw Smallport - running very rich.
bourny
4AGE 100kw Smallport - running very rich. Fri, 05 November 2004 00:52 Go to next message
Hey guys,
my car is running very rich after i replaced the timing belt, its blowing black smoking and i have a rather large power loss.
I'm chewing through petrol too! i've done about 100kms and used half a tank Sad
Any ideas why it would be running so rich? could the timing and stuff be out? causing this to happen?
Please help..
Bourny
bourny
Re: 4AGE 100kw Smallport - running very rich. Fri, 05 November 2004 02:15 Go to previous messageGo to next message
Come on guys, i need some help here...
BUMP!
b1gb3n
south Melbourne/KL
Re: 4AGE 100kw Smallport - running very rich. Fri, 05 November 2004 04:10 Go to previous messageGo to next message
my guess is cam gears not aligned properly. might be a few tooth out.
takai
Re: 4AGE 100kw Smallport - running very rich. Fri, 05 November 2004 08:42 Go to previous messageGo to next message
Timing
ae86drift
sydney.au
Re: 4AGE 100kw Smallport - running very rich. Fri, 05 November 2004 09:08 Go to previous messageGo to next message
gunna have to say the same thing. timing.
bourny
Re: 4AGE 100kw Smallport - running very rich. Fri, 05 November 2004 14:41 Go to previous messageGo to next message
Thats what i thought, timing.
But would it be retarded or advanced too much for it to run this rich? its blowing black smoke and apparently shoots flames Very Happy
I'm going to have a look at it tomorrow.
I can't really see the timing marks though, ill have to try and short out the ECU then see what its set at.
Ill let you know how i go.
CHeers
Bourny
b1gb3n
south Melbourne/KL
Re: 4AGE 100kw Smallport - running very rich. Sat, 06 November 2004 00:23 Go to previous messageGo to next message
if ur talking about dizzy, its probably retarded now since u say "shoots flames". Advance it (anti clockwise).
i suggest u look at cam gear marks and see if they are aligned as well.
Necros
Re: 4AGE 100kw Smallport - running very rich. Sat, 06 November 2004 00:26 Go to previous messageGo to next message
Firstly line up the timing mark (a little cut on the inside lip) on the crank pulley with 0 deg on the plastic cover that sits behind the crank pulley. Do this by turning the crank clockwise with a 19mm (might be 17mm) socket.
There are timing marks/ridges on the plate behind the cam gears which line up with dot/holes on one of the teeth of each gear...
The inlet cam gear is ~10 oclock and the exhaust is at ~5 oclock.
For the dizzy you need to have piston #1 at TDC. To do this take the spark plug out, get a long pencil sit it in the hole and turn the crank clockwise until the pencil stops coming up... Then just a tad more before it starts dropping.
Now make sure the dizzy rotor button is 10deg past #1 spark lead... You may need to play a bit and if the dizzy is way off you may need to remove it to rotate the gear one tooth. Btw the dizzy turns clockwise too... (Pistons 1-3-2-4).
I hear a timing gun is easier, but I dont have the points to short on the Diagnostics terminal so....
b1gb3n
south Melbourne/KL
Re: 4AGE 100kw Smallport - running very rich. Sat, 06 November 2004 00:36 Go to previous messageGo to next message
Necros wrote on Sat, 06 November 2004 11:26
this is referring to the dot where the came gear screw is i presume.
There should be marks on the edges of the cam gear that should align with indicators on the plate which should be AROUND 12oclock on both sides.
spend some time looking up the tech docs on main page. On the ignition section it shows how to align cam gears with diagrams. Easier that way. (i know coz i just farking changed my cams and its bloody tedious!!)
Necros
Re: 4AGE 100kw Smallport - running very rich. Sat, 06 November 2004 00:57 Go to previous messageGo to next message
I was refering to the marks on the edges of the gears Smile
I hope you changed your cam seals, last time I changed cams I didnt... It ran great for a couple of days, then the oil started coming out! smoke and oil everywhere... still cleaning it out!
b1gb3n
south Melbourne/KL
Re: 4AGE 100kw Smallport - running very rich. Sat, 06 November 2004 12:02 Go to previous messageGo to next message
Necros wrote on Sat, 06 November 2004 11:57
cam seals?? cam cover gasket u mean??
Necros
Re: 4AGE 100kw Smallport - running very rich. Sun, 07 November 2004 01:07 Go to previous messageGo to next message
The cam seals are the rubber rings that sit on the end of the cams. Behind the cam gears.
b1gb3n
south Melbourne/KL
Re: 4AGE 100kw Smallport - running very rich. Sun, 07 November 2004 04:45 Go to previous messageGo to next message
didnt change my cam seals. still have gear cover off and no oil leak yet. maybe u didnt put it back properly the 1st time
bourny
Re: 4AGE 100kw Smallport - running very rich. Mon, 08 November 2004 01:28 Go to previous messageGo to next message
Hey guys,
still no luck, i have checked the timing a few times, and its set right, 10 degrees BTDC, and 16 degrees BTDC with the ECU unshorted.
I don't understand why is running so rich, its only started doing it after i replaced the timing belt, and now i blows alot of black smoke and is chewing petrol. 20L / 100kms.. it isn't good..
Can someone please help!
Hunty
Re: 4AGE 100kw Smallport - running very rich. Mon, 08 November 2004 03:49 Go to previous messageGo to next message
sounds like a trip to a mechanic who can put on all the sensors and shit and adjust timing or whatever it needs
bourny
Re: 4AGE 100kw Smallport - running very rich. Mon, 08 November 2004 03:56 Go to previous messageGo to next message
Its been to the mechanic a couple of times, my brother is a mechanic.
They don't understand why is running so rich, they said it could be one of the temp senders.. i don't beleive it would be because it only started happening after they did the timing belt for me. they said everything was done right, timing etc.. but i don't beleive them.
When the car is stone cold it doesn't idle at 2k RPM like it use to. it starts and idles at 1100 RPM.
Any ideas anyone?? otherwise ill take it to another mechanic.
Bourny
Hunty
Re: 4AGE 100kw Smallport - running very rich. Mon, 08 November 2004 04:02 Go to previous messageGo to next message
have u tried another O2 sensor??? i remember when my one errr fell out the thing chewed thru hella fuel and my bumper was black as hell above the exhaust, threw in a new one from a camry and she was all sweet
bourny
Re: 4AGE 100kw Smallport - running very rich. Mon, 08 November 2004 04:12 Go to previous messageGo to next message
Hmmm thats one thing i haven't tried, ill see if i can find one from the wreckers, i don't have one lying around... Sad
The O2 sensor is the sensor located at the bottom of the extractors / exhaust manafold?
Thanks for your ideas Hunty...
Anyone got a spare O2 sensor lying around that i could have?
Very Happy
Bourny
Hunty
Re: 4AGE 100kw Smallport - running very rich. Mon, 08 November 2004 04:36 Go to previous messageGo to next message
yep thats the one, any one that has the same flange and similar dimensions will be fine as long as it is a 1 wire type, like i said mine was from a wrecked SV21 camry, i think, i got it at a wreckers for $15
Good luck!
bourny
Re: 4AGE 100kw Smallport - running very rich. Thu, 11 November 2004 22:30 Go to previous messageGo to next message
Ok, i have spoken to a few more people.. i haven't had a chance to replace the O2 sensor yet.. but that will be done satruday..
I have been told that the cams could be a tooth out. which lets it run, but not very well, would a tooth out cause black smoke and for me to use about 30L / 170kms?
I don't understand why its doing it. i keep getting told that the mechanic put it back together right, but i don't beleive them.
Please help!
Hunty
Re: 4AGE 100kw Smallport - running very rich. Thu, 11 November 2004 23:00 Go to previous messageGo to next message
you dont have a fuel leak anywhere do u??? i'd get the car running have some one give it a bit and have a look under the car and see if its dropping any fuel
bourny
Re: 4AGE 100kw Smallport - running very rich. Thu, 11 November 2004 23:45 Go to previous messageGo to next message
mmm i don't think i do.. but ill check.
Can the cams be 1 tooth out and cause it to run like this? really rich?
Please help...
Thanks.
b1gb3n
south Melbourne/KL
Re: 4AGE 100kw Smallport - running very rich. Fri, 12 November 2004 05:26 Go to previous messageGo to next message
If the cams are toothed correctly, check that all cables are connected if properly, assuming u have done so.
HighRolla
Re: 4AGE 100kw Smallport - running very rich. Mon, 15 November 2004 09:44 Go to previous message
Gee - sounds drastic. Check vacuum hose to fuel pressure regulator (FPR on end of fuel rail. Usually sees vacuum, if disconnected will see atmospheric pressure all the time shooting more fuel through the injectors for a given duty cycle).
They might have forgotten to reconnect a few things. Have a look around. But yeah it could be the cam timing out. Didn't know 4ages could drink that much. If all else fails take it to another mechanic, can't be great for the engine or the wallet when you fill up.
Previous Topic:Need better Ta22 Radiator
Next Topic:EMS DualSport tuning ?
Current Time: Sat Nov 21 01:42:56 UTC 2026
Total time taken to generate the page: 0.0083811283111572 seconds
