Toymods » Tech & Conversions » Injector Resistance settings
DiZ_
The Eastwood MASSIVE !
Injector Resistance settings Fri, 05 November 2004 13:37 Go to next message
On my ECU the setting for the injectors resistance is 2.4 ohm , and it has always been set to that. However the specs for the engine and injectors say 2.0 ohm , so now I guess I should investigate wether this setting should be changed , or should be left , and if it is to be changed will anything be affected.
All you aftermarket ECU gurus helpzor me.
Re: Injector Resistance settings Fri, 05 November 2004 13:43 Go to previous messageGo to next message
have you measured the resistance of the injectors?
can you adjust the resistance on the ECU in small steps? or is it just low/high?
DiZ_
Re: Injector Resistance settings Fri, 05 November 2004 13:47 Go to previous messageGo to next message
I can adjust the resistance in 0.2 ohm steps , I'll measure the resistance tomorrow but I'm quite sure the computer has had the resistance set too high for the injectors.
M.W.P.
Rocky Mountains, Canada
Re: Injector Resistance settings Sat, 06 November 2004 03:42 Go to previous message
DiZ_ wrote on Sat, 06 November 2004 00:17
Thats werid... i cant think of a reason why it would need to know it to that accuracy.
Normally low/high is enough.
Previous Topic:1ggte iradum vs platinum adn plug gap when increasing boost
Next Topic:Help!! need engine specs on 95 Townace
Current Time: Thu Nov 19 10:24:34 UTC 2026
Total time taken to generate the page: 0.0040020942687988 seconds
