Toymods » Tech & Conversions » Blacktop Fuel Controller
20 valve
icon5.gif  Blacktop Fuel Controller Fri, 05 November 2004 14:56 Go to next message
Can anyone help me out on this please, I have a 1998 Levin running a Blacktop with a few simple modifications, Iridium plugs, Splitfire leads, Cold Air Induction, Cat back exhaust system, and a 12 rib oil cooler. When I got the car there was a Fields SFC Hyper r Air/Fuel controller in the car and a spirit tech pro FCD.
The problem is when I got the car someone had wiped the air/fuel settings that were on the SFC and the FCD was messed with as well. I have tried setting them back up myself and the FCD is ok where as the SFC controller is hard to know where the Wright settings are without putting it up onto a dyno.
Does anyone have a Fields SFC Hyper r Air/Fuel or any other Air/Fuel controller fitted to a blacktop who could give me a baseline setup.
P.S. The engine is running the standard ECU.
Re: Blacktop Fuel Controller Fri, 05 November 2004 15:13 Go to previous messageGo to next message
whats wrong with running your stock motor on the stock ECU?
20 valve
Re: Blacktop Fuel Controller Fri, 05 November 2004 15:51 Go to previous messageGo to next message
Because they Run Very rich at the top end.
Thanks for all the help Rolling Eyes
[Updated on: Fri, 05 November 2004 15:51]
Re: Blacktop Fuel Controller Fri, 05 November 2004 16:20 Go to previous messageGo to next message
oookay then.... no offence intended.... Rolling Eyes
so the problem is that they don't flow enough air at top end when stock and fuelled by stock ECU?
and you have intake (CAI) and exhaust mods (cat back) to increase top end air flow?
so these mods have decreased top end air flow? or haven't increased it enough to take advantage of the stock overfuelling?
each motor is individual, and the only way to get the correct setting when you start stuffing around with stock fuel maps IS to put it on a dyno. how else can you quantify what effect the changes you make are having?
are you sure they were actually in use before you got the car? maybe they had been wiped as they were not being used? or were never programmed at all?
20 valve
Re: Blacktop Fuel Controller Fri, 05 November 2004 17:46 Go to previous messageGo to next message
The problem is the stock ECU is a greedy pig for fuel at the top end of the revs.
The mods down to the car have improved it a bit but it’s still too rich for my liking.
I agree with what you say with putting the car on a dyno to
Get the best setup possible but I would like to get a baseline and have a run before I put it on a dyno, as I am waiting on aftermarket trumpets to arrive before it goes on the dyno.
The 2 piggy backs were definitely in the car and were being used while it was in Japan, it was the person who imported the car who made a mess of the settings and wiped them before I bought the car from him.
oldcorollas wrote on Fri, 05 November 2004 16:20
20 valve
icon5.gif  Re: Blacktop Fuel Controller Sat, 06 November 2004 10:27 Go to previous messageGo to next message
Help Please
20 valve
icon5.gif  Re: Blacktop Fuel Controller Sun, 07 November 2004 22:48 Go to previous messageGo to next message
Bump Idea
Re: Blacktop Fuel Controller Sun, 07 November 2004 23:31 Go to previous message
tried emailing the manyfacturer or distributor for the product? surely they would have some baselines...
by the reponse here so far, it looks like not many people either have your controllers, or are not using them on stock motors..
good luck.
Previous Topic:AW 11 guys, brake pad suggestions
Next Topic:1jz FCD
Current Time: Sat Oct 31 13:17:14 UTC 2026
Total time taken to generate the page: 0.097913980484009 seconds
