Toymods » Tech & Conversions » RWD 4AGE exhaust manifold
dorikin
NE Melbourne
RWD 4AGE exhaust manifold Sun, 06 October 2002 14:24 Go to next message
just a quick question about the durability of these parts. i know they flow well, and are almost as good as many aftermarket extractors (when mated to correct length/size secondary pipes and exhaust).
i ask as i plan to tidy my engine bay up further, including a quick match port, fine sand, remove of top cover and mounting tabs and have the manifold HPC coated. however i don't want this expense if the manifold is likely to crack any time soon after.
another question. can the RWD manifold be easily modified to fit a 20V head? ie, enough material available to slot bolt holes at each end?
pepsicola
Re: RWD 4AGE exhaust manifold Sun, 06 October 2002 18:12 Go to previous messageGo to next message
do you think will that fit, if I keep everything else standard?
like not reroute anything.
RA23_Sean
Western Sydney
Re: RWD 4AGE exhaust manifold Mon, 07 October 2002 01:18 Go to previous messageGo to next message
I think the 20V heads have different shaped ports to the 16V heads.
Bill Sherwood
Brisbane / Gold Coast
Re: RWD 4AGE exhaust manifold Mon, 07 October 2002 01:23 Go to previous messageGo to next message
The ports are the same on both heads, but the studs on the far ends are in slightly different positions, but it's an easy mod (slot the holes in the manifold) to make them fit.
dorikin
NE Melbourne
Re: RWD 4AGE exhaust manifold Mon, 07 October 2002 09:24 Go to previous messageGo to next message
ok, so in know about the 20V ports,a nd the 16V manifold fitting.
could anyone shed some light on the initial durability question???
dorikin
NE Melbourne
Re: RWD 4AGE exhaust manifold Wed, 09 October 2002 08:20 Go to previous messageGo to next message
anyone had experience with the RWD manifolds craking or failing in any other way under normal circumstances?
pepsicola
Re: RWD 4AGE exhaust manifold Wed, 09 October 2002 11:50 Go to previous message
I meant will the exhaust manifold be extremely closed to the clutch cylinder, and in the way of the clutch lines??
Previous Topic:100kw 4age to RWD
Next Topic:4A-FE to 4A-GE
Current Time: Wed Oct 21 18:01:31 UTC 2026
Total time taken to generate the page: 0.0046799182891846 seconds
