Toymods » Tech & Conversions » tacho issue's
juzzo84
Hornsby, N.S.W
icon4.gif  tacho issue's Fri, 05 November 2004 22:38 Go to next message
heya guys can anyone please help me out with this lil question.
i have a ae71 corolla and want to run the standard tacho with a quad coil setup running off a microtech ltx8 ecu, what do i have to do to the wiring to make it work off the 4 coils, or is there some where off or to the ecu that i can bridge off??? cheers
Justin
ViPeR_NiPPleX
VIC, Sth Frankston.
Re: tacho issue's Fri, 05 November 2004 23:14 Go to previous messageGo to next message
good morning Smile
umm, i am not at all sure this is correct, but from what little electronics knowledge i have, and from things i have heard, this is how its done...
http://www.abbeysound.com.au/jnicol/diodecoil.jpg
sorry about the quality n such. I made it myself Smile
Not sure about the current capability of the diodes, i wouldnt think it would be heaps. Hopefully this gives an idea..
James
juzzo84
Hornsby, N.S.W
Re: tacho issue's Fri, 05 November 2004 23:45 Go to previous messageGo to next message
thanks for the diagram, i just need to know the specs for the diodes!! Smile
ViPeR_NiPPleX
VIC, Sth Frankston.
Re: tacho issue's Fri, 05 November 2004 23:56 Go to previous messageGo to next message
you could try some 1n5404 diodes, rated to 8 amps.
sideshow
Re: tacho issue's Sat, 06 November 2004 02:28 Go to previous messageGo to next message
i have had back feed which caused a miss using diodes
but maybe i had too small diodes
if the diodes dont work i have proper autronic tacho boosters
4 signals in and one signal out
but yr microtech should have a tacho output
its a blue wire with white trace
i have cheap signal noosters specific for microtechs
they amplify the tacho signal from the microtech
[Updated on: Sat, 06 November 2004 02:29]
Re: tacho issue's Sat, 06 November 2004 02:34 Go to previous messageGo to next message
plus if you find you are popping the diodes regularly (perhaps from resonance in the coils and HEI systems that run at higher voltages) you might want to add some kind of input protection to each incoming signal - probably a relatively robust zenner diode that goes to ground? (e.g. if input signal is >50V then send off to ground - probably via a resister for current limiting purposes.)
the electronic's guys will know more about wiring up something more durable that your diagram.
i'm just a hack when it comes to this stuff,
juzzo84
Hornsby, N.S.W
Re: tacho issue's Sat, 06 November 2004 06:49 Go to previous messageGo to next message
cheers for your help guys, i will give it a go, and see what happens!!
thanks everyone
Justin
Henn
Rosanna, Melb
Re: tacho issue's Sat, 06 November 2004 08:29 Go to previous messageGo to next message
If you have a tacho out from your ECU I can send you a circuit that'll fix this signal so you can plug it into your stock tacho. It'll be a little sluggish, but works fine.
Gimme a PM if you're interested. I'll have to draw it and scan it. Needs a relay, a transistor and a resistor, so should cost ~$5 to make.
Hen
Re: tacho issue's Sat, 06 November 2004 12:37 Go to previous messageGo to next message
coil1--D1>--|
coil2--D2>--|
coil3--D3>--|
coil4--D4>--|
|----<ZD1--tacho
R1
GROUND
D1,2,3,4 (add as many as you have coils) are 1N4004 - they don't have to carry stuff all current, no need for 8 amp numbers
ZD1 is a 1N4744
R1 is a 1K resistor
Should cost less than $1
CelicaRA45
nth ringwood, Victoria
Re: tacho issue's Sat, 06 November 2004 23:38 Go to previous messageGo to next message
on the motec we run 1 of the aux to run tacho then we use a relay to modify the signal can you do that with the micro tech
John S
Re: tacho issue's Sun, 07 November 2004 03:35 Go to previous messageGo to next message
Go see Sixworks for a tacho booster/converter. A few friends with aftermarket ecu's have them and the tach works great. He has a website too at sixworks.com.au.
cheers,
John.
Re: tacho issue's Sun, 07 November 2004 07:28 Go to previous message
http://www.comcen.com.au/~sheehan/tachoadaptercct. jpg
Previous Topic:running high boost on stock block????
Next Topic:Making 250-300rwkW with 7m-gte HELP PLZ
Current Time: Fri Nov 20 01:19:53 UTC 2026
Total time taken to generate the page: 0.06800103187561 seconds
