Toymods » Tech & Conversions » 1g-gte onto ra28, whats the deal?
jcmunga
adelaide
1g-gte onto ra28, whats the deal? Sat, 06 November 2004 02:55 Go to next message
ok, so iv done alot of reading and it seams that the 1G is the best way to go but there is mixed info as to what needs to be done to fit it so im looking for clarification on a few things.
some say that new engine mounts are needed but others say that the origional ones can be used with mods to them.
on another site i read that you may need to cut away at the front for the radiator to fit, is this true?
if i have a mid rear sump can i use the origional ra28 x member do i need the ra23, or do they both need mods and or does the sump need to be modified
i obviously need a custom x member for the gear box.
does a shortened hilux diff bolt straight up?
also i have found that the 1g-gte is almost impossibe to find in adelaide, does any one have any suggestions??
EvilJack
Sutho/Hills NSW
Re: 1g-gte onto ra28, whats the deal? Sat, 06 November 2004 03:05 Go to previous messageGo to next message
pays to do a search mate
http://forums.toymods.org.au/index.php?t=msg&t h=47778&rid=1334&S=975e7a5eb5ddcb40b261a27 9c8e7122f&pl_view=&start=0
http://forums.toymods.org.au/index.php?t=msg&t h=38152&rid=1334&S=975e7a5eb5ddcb40b261a27 9c8e7122f&pl_view=&start=0
Cool
M.W.P.
Rocky Mountains, Canada
Re: 1g-gte onto ra28, whats the deal? Sat, 06 November 2004 03:37 Go to previous messageGo to next message
18R engine mounts are fine, but a spacer is needed on one side so it clears the steering box.
Not if you dont run the clutched fan.
Run thermos instead.
RA23 and RA28 xmembers are the same.
Im not too sure about this, but ive heard the W50 mount can be used if some holes are redrilled.
No.
If you find one, let me know cos im also after one in the next couple of months for my RA28.
[Updated on: Sat, 06 November 2004 03:37]
EnFlaMEd
Re: 1g-gte onto ra28, whats the deal? Sun, 07 November 2004 05:43 Go to previous messageGo to next message
Jeeze i see 1ggtes for sale quite often in the trader. If you really are having heaps of problems ill sell you mine with 5spd 70,000ks on it and an accident damaged GZ20 soarer for $3500
jcmunga
adelaide
Re: 1g-gte onto ra28, whats the deal? Sun, 07 November 2004 11:21 Go to previous messageGo to next message
really? that could be worth a look, how badly damaged is it, do you have any pics?[
MR 1JZ
Re: 1g-gte onto ra28, whats the deal? Mon, 08 November 2004 01:26 Go to previous messageGo to next message
I have a motor in need of a head gasket you can buy, with auto box and possibly loom and computer for $700 Very Happy
M.W.P.
Re: 1g-gte onto ra28, whats the deal? Mon, 08 November 2004 04:55 Go to previous messageGo to next message
MR 1GGTE wrote on Mon, 08 November 2004 11:56
Is that the one you said was missing the turbos and needed the bearings replacing?
ra23celica
Re: 1g-gte onto ra28, whats the deal? Mon, 08 November 2004 05:47 Go to previous messageGo to next message
You have got the TA23 crossmember confused with the RA23 one, same as the RA28 as mentioned above. TA23 X-mems are used when you fit a 1G-GE or a 2/3T series motor to your RA28.
Use the mid-rear sump however you will have to shorten the back of it with a cut and shut to clear the steering arm.
Not quite a 'custom' g/box crossmember but two 3mm plates welded
to the top of it and a pair of new holes drilled in the forward section and the previous forward holes drilled through the plate.
Shortened Hilux diff will have either a F or G series flange plate and that is not compatible with the T series driveshaft. Change flange plates or shorten a Hilux driveshaft to suit.
MR 1JZ
Re: 1g-gte onto ra28, whats the deal? Mon, 08 November 2004 07:16 Go to previous message
M.W.P. wrote on Mon, 08 November 2004 15:25
nope thats the other one Very Happy
I have two Very Happy
The loom and computer might not be available at the end of the week tho, they are pretty much sold pending payment so i shouldnt have written that...I have the bearing one and the top end one, i suppose you could put them both together to make one good one Very Happy
Previous Topic:reuseing a head gasket???
Next Topic:Installing Celicamad Boost Controller
Current Time: Sat Oct 24 22:21:56 UTC 2026
Total time taken to generate the page: 0.0046348571777344 seconds
