Toymods » Tech & Conversions » AE86 Handbrake Adjustment (SOLVED)
genkin
AE86 Handbrake Adjustment (SOLVED) Sat, 06 November 2004 07:09 Go to next message
Problem solved!
Quote:
totally loosen off the HB adjustment nuts.
pump foot brake at least 10 times (fully in).
re-adjust handbrake so it has 6 clicks.
hi kids, i have a JDM ae86 with disk rear end...
in the past the handbrake has worked just fine, feels good and locks with minimal effort or pressure...
now recently i noticed that the handbrake lost the ability to hold the rear disks tightly, even when parked, you can still push the car forward with handbrake on. I have checked handle adjustment pads and fluid, all is fine. also greased all cable parts.
can anyone please offer me helpful advise.
thank you
[Updated on: Mon, 08 November 2004 08:38]
Simon-AE86
Banned user
ADELAIDE - The Drift City
Re: AE86 Handbrake Adj. HELP!!?? Sat, 06 November 2004 08:43 Go to previous messageGo to next message
Have you checked the sump plug ? it might be that
Sprinter
Re: AE86 Handbrake Adj. HELP!!?? Sun, 07 November 2004 00:30 Go to previous messageGo to next message
Hi Genkin,
Not sure if Simon is taking the piss but check 2 things in particular. The handbrake lever assembly on the caliper has a small pin that swivels to allow more clearance when working on the caliper. Swing it round so the tab is pushing the lever out (hard to describe but when you find you should be able to work it out).
The second thing is bleed the rear brakes. The integrated hand brake is a shit to keep working consistently and you will have to continually bleed the buggers. Get used to it Confused
Good luck,
Denis
ae95
Re: AE86 Handbrake Adj. HELP!!?? Sun, 07 November 2004 02:49 Go to previous messageGo to next message
remove the trim around the handbrake and tighten it up via the 2 10mm nuts
genkin
Re: AE86 Handbrake Adj. HELP!!?? Sun, 07 November 2004 04:15 Go to previous messageGo to next message
sprinter: i will go try that now.
ae95: i have already adjusted this.
Simon-AE86
Banned user
Re: AE86 Handbrake Adj. HELP!!?? Sun, 07 November 2004 05:25 Go to previous messageGo to next message
of course i was taking the piss, what better way to bump the thread up Wink
btw i have blead the brakes... slight improvement but not much at all really
ae95
Re: AE86 Handbrake Adj. HELP!!?? Sun, 07 November 2004 08:56 Go to previous messageGo to next message
setup a hydraulic handbrake setup
genkin
Re: AE86 Handbrake Adj. HELP!!?? Sun, 07 November 2004 10:22 Go to previous messageGo to next message
Sprinter: I had a look under the calipers. couldnt see the 'pin' u were refering to. only pin i saw was the cotter pin holding HB cable in place.
although i did notice that when the handbrake is fully engaged, it doesnt seem to be able to go any further, even on the caliper assembly! and it still doesnt get full lock!!!
i might get a brake expert to have a look. im stumped!
AE95: hydraulic handbrake is not feisable for me. cost to much, and a waste on a daily driver i reckon.
Simon-AE86
Banned user
Re: AE86 Handbrake Adj. HELP!!?? Sun, 07 November 2004 10:56 Go to previous messageGo to next message
put new pads in
genkin
Re: AE86 Handbrake Adj. HELP!!?? Sun, 07 November 2004 11:45 Go to previous messageGo to next message
hmm, maybe i need new pads, although there is still plenty of material left.
it just doesnt seem to 'reach' enough.
Sad but i like my wimax zger.
what is a good bitey rear pad for ae86 disc?
Simon-AE86
Banned user
Re: AE86 Handbrake Adj. HELP!!?? Sun, 07 November 2004 11:55 Go to previous messageGo to next message
just get some bendix ones
genkin
Re: AE86 Handbrake Adj. HELP!!?? Mon, 08 November 2004 08:35 Go to previous message
problem solved!
handbrake works super locky now! LOCK LOCK!
heres how i did it (i assume this is the 'proper' way.
and voila! go for a locky lock session around your neighbourhood!
thanks to all those who gave me suggestions and kept me tinkering.
Previous Topic:brake pads
Next Topic:TruTrac Diff noisy?
Current Time: Sat Oct 24 14:56:47 UTC 2026
Total time taken to generate the page: 0.048619031906128 seconds
