Toymods » Tech & Conversions » gen 2 3sge cams regrind
Matt-itude
Perth, Western Australia
gen 2 3sge cams regrind Sun, 07 November 2004 01:25 Go to next message
is there any advantage/point to getting cams regrinded to increase performance? i have a spare set in my garage and i am wondering if i could get any cheap performance out of them. also where abouts in perth would i be looking at getting this done, and how much would i expect to pay for it?
510rob
Vancouver
Re: gen 2 3sge cams regrind Sun, 07 November 2004 22:31 Go to previous messageGo to next message
There are no rockers in a 3SG head, so you can't fiddle with the base circle, so you can't radically change either the lift or duration aspects by grinding; if you peel out that last bit of base circle within the lash compensation allowance, will only net a minimal change and cost yourself $$$ for a bunch of thick shims...
I've talked to a local cam regrinder in my area, and he wasn't at all interested in hard-face welding that much material onto the lobes to do a custom grind...
That leaves 2 options...
You can buy a pair of aftermarket Japanese cams from Blitz, HKS, Toda, and perhaps others
Or you can call Richard at TED Components and get a set of custom billet cams (http://www.tedcomponents.com/3sgte.htm)
TED are the only people I'm aware of that do billet cams to any specifications geometrically possible within the limits of the mechanical assembly, or modify the head to accept higher lift cams if you want to go for broke!!! (the lifter bores on a gen2 non-RC head won't take the higher lift cams without clearancing the lifter bores for big peaks)
Matt-itude
Re: gen 2 3sge cams regrind Mon, 08 November 2004 04:05 Go to previous messageGo to next message
thanks for the reply, but because i am situated in perth, that bloke isn't much help to me. but thank you for ur advice
CelicaRA45
nth ringwood, Victoria
Re: gen 2 3sge cams regrind Mon, 08 November 2004 05:23 Go to previous messageGo to next message
to hard face your cam sabout $50 .00 a lobe normaly and if you go to high in lift it will spit the shim out
510rob
Vancouver
Re: gen 2 3sge cams regrind Mon, 08 November 2004 08:38 Go to previous messageGo to next message
With respect to the shim spitting problems...
if it's a Gen2 motor (which the ST185 came with), you can literally drop in the shimless bucket type lifters out of a later Toyota 1ZZ-FE motor, thereby forever eliminating the possibility of spitting a shim! (drop in still requires you to maintain proper cam clearance with the correct sized lifters, of which I believe they make 42 different incremental heights...)
CelicaRA45
Re: gen 2 3sge cams regrind Mon, 08 November 2004 08:51 Go to previous message
you can also buy gen 3 buckets here from your toyota dealer then you need valve springs and new retainers crom moly retainers 200 a set 16 gen 3 shims for under bucket 12 each valve springs 150 a set and the buckets 24 each from toyota
Previous Topic:Water/methanol injection
Next Topic:smokey 1jz
Current Time: Mon Oct 26 14:22:10 UTC 2026
Total time taken to generate the page: 0.21141195297241 seconds
