Toymods » Tech & Conversions » running high boost on stock block????
20vturbo
icon14.gif  running high boost on stock block???? Sun, 07 November 2004 02:48 Go to next message
hey guys, i was wondering,would slightly bigger turbo, a metal head gasket( be it thicker or standard),port and polish, uprated fuel injectors and upgraded uce save for stock block running on high boost?
let's take an mr2 3sgte engine as an example, swap the original ct26 turbine to TDO6 20g turbine,bigger injector, thicker metal gasket and port and polish to alter the compression and uses apexi s-afc. would this car runs safe with a 1.5 bar of boost, as it's original engine block was stock? or, does this setup will only work on stronger engine block,for example cast iron block (4g63 vr4, ca18, 4age?
Re: running high boost on stock block???? Sun, 07 November 2004 02:50 Go to previous messageGo to next message
3S-GTE has a cast iron block and is very tough. 1.5 bar is no problem with proper tuning.
20vturbo
Re: running high boost on stock block???? Sun, 07 November 2004 03:06 Go to previous messageGo to next message
then, how about aluminium blocks such as dohc vtec block? do we need to strenghten the block in order to run he same boost?
Re: running high boost on stock block???? Sun, 07 November 2004 03:11 Go to previous messageGo to next message
It depends entirely on the engine. The SR20 is all alloy and can take a lot of boost, but some Honda alloy engines require strengthening to handle a decent amount of boost.
20vturbo
Re: running high boost on stock block???? Sun, 07 November 2004 06:38 Go to previous messageGo to next message
any good tips on this kind of mod? example,con-rod replacement? blabla?
Re: running high boost on stock block???? Sun, 07 November 2004 07:30 Go to previous message
Here's the simplest tip: $ Shocked
Previous Topic:Respray body / retrime interior fix
Next Topic:tacho issue's
Current Time: Fri Nov 20 01:45:05 UTC 2026
Total time taken to generate the page: 0.0075969696044922 seconds
