Toymods » Tech & Conversions » Coil Packs
EMP-2TG
Carlingford, Sydney
Coil Packs Mon, 07 October 2002 02:42 Go to next message
Im after 4 coil packs to run off a microtech mtx8 computer
i was wondering which 1's are good and why etc
thanks Smile
CelicaRA45
nth ringwood, Victoria
Re: Coil Packs Mon, 07 October 2002 07:30 Go to previous messageGo to next message
i have a dumb motec coil pack that the computer controls find out if the microtec will run it
SUPRAGTE
North Sydney
Re: Coil Packs Mon, 07 October 2002 09:30 Go to previous messageGo to next message
Maybe try the bosh ones microtech sell Josh, Dont know how much they are.
Toyota coils are very good, the 7mgte ones are great. Low resistance on the primary which allows current to flow faster which is better for hi rpm spark because it continues to supply plenty of magnetic flux for the secondary to use.
But the 7mgte one's are wastespark, ie one coil for two cylinders.
EMP-2TG
Carlingford, Sydney
Re: Coil Packs Mon, 07 October 2002 11:17 Go to previous messageGo to next message
I think the 4agze 1's arnt waste spark
and i think the bosch 1's cost about $120 or so
well ill keep my eye's out
Grega
melbourne.victoria.austra...
Re: Coil Packs Mon, 07 October 2002 20:19 Go to previous messageGo to next message
emp - if you have the two coils from the GZE (ie: ae92 onwards) yes they are waste spark dude.
EMP-2TG
Carlingford, Sydney
Re: Coil Packs Mon, 07 October 2002 22:15 Go to previous messageGo to next message
ok thanks
my bad Embarassed
well ive been offerd a set of bosch 1's so ill be buying those
thanks all Smile
EMP-2TG
Carlingford, Sydney
Re: Coil Packs Thu, 10 October 2002 11:45 Go to previous messageGo to next message
ok that deal fell through
i was wondering what the bosch coil packs that come with the mtx8 are worth new?
TE72_Turbo
Re: Coil Packs Thu, 10 October 2002 12:14 Go to previous messageGo to next message
If you want to run waste spark, Haltech sell a quad coil pack for $78. I reckon that's excellent value, since you will pay around $55 each for a single bosch coil. I used two packs on my 3TGTEU (8 plug 4 cylinder) and cant fault them.
Phil
EMP-2TG
Carlingford, Sydney
Re: Coil Packs Thu, 10 October 2002 12:36 Go to previous messageGo to next message
cool i had a look at the haltech site (not that they had much info on them) but they look like they could be the goods Smile
so these will work with the mtx8 alright?
SUPRAGTE
North Sydney
Re: Coil Packs Fri, 11 October 2002 10:53 Go to previous messageGo to next message
Yep they'll work with the mtx8 fine Josh, just make sure its the MT"X" model you get.
kingmick
Banned by his request
moved to tamworth
Re: Coil Packs Fri, 11 October 2002 11:20 Go to previous messageGo to next message
we use the LS1 comdomdore coil packs {1 for each pot} on our race engines and they handle well over 800hp with no problems and easy to get and cheap run with both motec and autronic.
mick
EMP-2TG
Carlingford, Sydney
Re: Coil Packs Fri, 11 October 2002 14:29 Go to previous messageGo to next message
Yeah i already have the computer and it sure is an mt"x"8 Smile
is it worth sending the computer off to get it upgraded to the lastest firmware?
and get a base map for say a 4age put on it?
kingmick
moved to tamworth
Re: Coil Packs Sat, 12 October 2002 08:19 Go to previous messageGo to next message
it depends on what you want from the computer! if its a street car and your on a tight budget no, if the skys the limit give it to a mate and get a m800! with dash and a few sensors will only be $20k Smile. if for the street just get it tuned properly and forget it.
mick
SUPRAGTE
North Sydney
Re: Coil Packs Sun, 13 October 2002 02:19 Go to previous messageGo to next message
Yeah i'd send it into Microtech and get it upgraded. If you do it through Merve they probably wont charge him cause he's known Domonic for over 10years and he always helps Merve out.
Get the 4age base maps put in then get Merve to tune it up, he's genius with 4age's as you know.
I like the new firmware with the laptop programability, other bonus with the firmware upgrade i now have 4 positions on my eeprom instead of two.
If you send it down Monday i'm comming to Taree on Friday i could bring it back. Probably beter to do it through Merve though.
Kingmick, who make the coils for Holdens? i wouldn't want any of the injection or ignition parts off old push rod V8's. Smile
Just a little dig, Smile i'v got a Holden company car and it's barely Holden together after 60 thou on it.
EMP-2TG
Carlingford, Sydney
Re: Coil Packs Sun, 13 October 2002 05:11 Go to previous message
yeah ill be back in taree in a few weeks i hope
i broke my diff so it will be when i fix that
ill go see merve then Smile
see if he can hook me up with the goodnes
Previous Topic:how much room do you need for a conversion?
Next Topic:Where is the fuel pump wire...
Current Time: Fri Nov 20 19:42:55 UTC 2026
Total time taken to generate the page: 0.065202951431274 seconds
