Toymods » Tech & Conversions » 1G-GTE Ox sensor
Crossy
1G-GTE Ox sensor Sun, 07 November 2004 09:30 Go to next message
one of the plugs for the ox sensor on my motor go mashed in the engine install...
need to know which wires goto which...
on the ox sensor side i have 2 black wires and a blue wire
on the loom side i have a browny-white, black/red and red green wires
thanx
MaT
matt_84
Ipswich
Re: 1G-GTE Ox sensor Sun, 07 November 2004 09:39 Go to previous messageGo to next message
Its a 3 pin connector, on mine, it goes;
blue to white/brown
left black to red/green
right black to black/red
This is looking at the connector with the blue wire uppermost.
matt_84
Ipswich
Re: 1G-GTE Ox sensor Sun, 07 November 2004 09:41 Go to previous messageGo to next message
But I have shielding over mine, so the left/right designation only applies at the connector end; it may actually be the other way round at the sensor end.
Crossy
Re: 1G-GTE Ox sensor Sun, 07 November 2004 09:45 Go to previous messageGo to next message
looking at the connector from the terminal side or the wire side?
matt_84
Ipswich
Re: 1G-GTE Ox sensor Sun, 07 November 2004 09:46 Go to previous messageGo to next message
Terminal side
Crossy
thanx heaps dude
matt_84
Ipswich
Re: 1G-GTE Ox sensor Sun, 07 November 2004 09:50 Go to previous messageGo to next message
No worries, good luck with it.
Re: 1G-GTE Ox sensor Sun, 07 November 2004 12:23 Go to previous messageGo to next message
2 black wires are for heater and have no polarity, blue wire is for signal Smile
matt_84
Ipswich
Re: 1G-GTE Ox sensor Sun, 07 November 2004 13:24 Go to previous messageGo to next message
Cheers oldcorollas, on that note, from my 1g diagram, it has what must be the two heater wires, coming from the main efi relay, and the other from the HT pin on the ecu (which i'm assuming is heater).
Why does it have two inputs for the heater?
Re: 1G-GTE Ox sensor Sun, 07 November 2004 13:47 Go to previous messageGo to next message
so one wire is direct from the EFI relay and must be +12V??
it may be that the ECU controls when the heater is on and off, by means of 'closing' the heater circuit, ie grounding the heater.
the heater would not have 2 positive power inputs.
the third wire goes to Ox or similar on ECU?
matt_84
Ipswich
Re: 1G-GTE Ox sensor Sun, 07 November 2004 13:52 Go to previous message
Ah yep thats probably it, the ecu switches the HT pin to ground so current can flow through the heater. I get it now, I didn't think of that Embarassed
Yeah, the third wire goes to the OX pin.
Previous Topic:Custom engine mounts
Next Topic:Do i need new fuel filter?
Current Time: Sun Nov 1 12:17:20 UTC 2026
Total time taken to generate the page: 0.0094211101531982 seconds
