Toymods » Tech & Conversions » Brake pedal goes spongey after hard corner for first push
RobST162
Brake pedal goes spongey after hard corner for first push Sun, 07 November 2004 22:22 Go to next message
any ideas?
if the rotors were shifting, pushing the piston back in... hmmm
I loosish hub nut?
allencr
tallahassee FL usOFa
Re: Brake pedal goes spongey after hard corner for first push Sun, 07 November 2004 23:35 Go to previous messageGo to next message
it's called "knock back", but doesn't happen much on type calipers that aren't fixed mount & opposing piston. what are yours???
something is loose/unadjusted or flexing.
[Updated on: Mon, 08 November 2004 01:55]
RWDboy
Re: Brake pedal goes spongey after hard corner for first push Mon, 08 November 2004 00:02 Go to previous messageGo to next message
I think I'll put money on needing the calipers reco'd... Smile
RobST162
Re: Brake pedal goes spongey after hard corner for first push Mon, 08 November 2004 00:41 Go to previous messageGo to next message
Stephen, it wasn't doing it before I went a replaced my bearing that's all.. and the seals look pretty good on these brakes
but I think I did everything up to spec.
if feels exactly like the piston is getting pushed back, and then i have to push it back into place and it is fine till I go arond another corner.. the harder I corner, the further I have to push my pedal to restore nomal feel lol
RWDboy
Re: Brake pedal goes spongey after hard corner for first push Mon, 08 November 2004 00:58 Go to previous messageGo to next message
Hrm - I'd be checking the work again if that's the case. It could either be the caliper needs help or something is loose back there!
RobST162
Re: Brake pedal goes spongey after hard corner for first push Mon, 08 November 2004 01:01 Go to previous messageGo to next message
yeah calipers have been champion for ages so I guess time to take the wheel off and take a quick look again
STR8 2.8
Re: Brake pedal goes spongey after hard corner for first push Mon, 08 November 2004 01:04 Go to previous messageGo to next message
have you tried bleeding the brakes?
[Updated on: Mon, 08 November 2004 01:05]
ChuckLandwehr
Re: Brake pedal goes spongey after hard corner for first push Mon, 08 November 2004 01:58 Go to previous messageGo to next message
Hi Rob, check your wheel bearings buddy. The caliper is bolted to the strut, under lateral loads, a loose wheel bearing will allow the disc to tilt in relation to the caliper. This would effectively push back your piston.
regards Chuck.
RobST162
Re: Brake pedal goes spongey after hard corner for first push Mon, 08 November 2004 02:01 Go to previous messageGo to next message
hey Chuck thanks dude
I have only very recently had the bearing replaced (ie, this is why I had it all off onn Saturday, and noticed the problem yesterday)
got the job done at a workshop and put it all back together myself
perhaps the hub-nut isn't tight enough? but i did it up really tight, and have taken hubs on and off plenty before and never had a problem.. Sad
rob_RA40
c'town, NSW
Re: Brake pedal goes spongey after hard corner for first push Mon, 08 November 2004 02:12 Go to previous messageGo to next message
RobST162 wrote on Mon, 08 November 2004 13:01
this doesnt sound right at all... wouldnt doing it up tight collapse the bearing?
or are we talking about different things
RobST162
Re: Brake pedal goes spongey after hard corner for first push Mon, 08 November 2004 02:16 Go to previous messageGo to next message
the books says it has to be around 137 ft/lb on the nut
that's pretty tight... you know you gotta take 'em off with a big breaker and stuff..
the only thing that holds the driveshaft onto the hub/bearing is this nut
if it was loose I could imagine movement in there.. but I just inspected all the components.. they seem pretty tight
I will check my hub-nut again
rob_RA40
c'town, NSW
Re: Brake pedal goes spongey after hard corner for first push Mon, 08 November 2004 02:34 Go to previous messageGo to next message
ahh k, yeah stick with the books specifications.
RobST162
Re: Brake pedal goes spongey after hard corner for first push Mon, 08 November 2004 02:37 Go to previous message
thanks rob kinda wierding me out
sick of continual dramas over the last three weeks when i have had 3 years of awesome reliablility.. oh well, once they are sorted she'll be sweet as again
the pads are in a fixed mount with the pistons operating off a hinge at the top whic slide down over the pads.. usual deal
Previous Topic:3SGTE Gen 2 throttle body enlarging
Next Topic:custom surge tanks
Current Time: Wed Oct 28 02:00:57 UTC 2026
Total time taken to generate the page: 0.0048120021820068 seconds
