Toymods » Tech & Conversions » Quick question: ZE block with GE head?
pepsicola
Quick question: ZE block with GE head? Mon, 07 October 2002 06:16 Go to next message
I know the ze block it's tougher.
What's the draw back with using a ZE block in a 4age?
Thanks.
Youngy
Eskilstuna, Sweden
Re: Quick question: ZE block with GE head? Mon, 07 October 2002 06:21 Go to previous messageGo to next message
Here are the first things that come to mind
1. An NA motor with stuff all compression, assumming you also use the ze internals
2. I didn't think the ZE block itself was any different from the 100kw GE block anyway. Same Crank diameter and all
3. If the crank and rods are used with nice high compression pistons it would be an advantage as the rods in the ze are stronger than the ge's etc
4. Will you ever get enough power out of an NA motor to need the ze block anyway?
Food for thought is all.
Blown86
Re: Quick question: ZE block with GE head? Mon, 07 October 2002 06:24 Go to previous messageGo to next message
If the supercharger is attached to the block and working, your laughing!!
feral4mr2
Bundaberg, Qld.
icon7.gif  Re: Quick question: ZE block with GE head? Mon, 07 October 2002 06:52 Go to previous messageGo to next message
Freak you wouldnt need to change the head, just the inlet manifold etc. ....i drove my mr2 around as a na ze motor for nearly a month, before i got the turbo on it, i changed all the inlet manifold and stuff over, so i didnt have to worry bout doing it when i got the turbo...it was prity gutless, but it got going around 5000rpm. Very Happy i could still drive around town and on the highway, it was just like driving a celica.. Laughing
pepsicola
Re: Quick question: ZE block with GE head? Mon, 07 October 2002 07:08 Go to previous messageGo to next message
someone is selling a 4age engine with a ze block and internal.
I just want to know if it's anything I should be wear of this enigne. so no supercharger or anything. just a NA 4age with ze block and internal.
Ribbo
Northern Beaches
Re: Quick question: ZE block with GE head? Mon, 07 October 2002 07:19 Go to previous messageGo to next message
umm if u plan on turboing or supercharging then its perfect. But if ur wanted N/A then it wouldn't really be any good with the ZE internals as it would be gutless cos of the compression
pepsicola
Re: Quick question: ZE block with GE head? Mon, 07 October 2002 07:21 Go to previous messageGo to next message
ok...then I don't want it.
Thanks guys.
Ribbo
Northern Beaches
Re: Quick question: ZE block with GE head? Mon, 07 October 2002 07:44 Go to previous messageGo to next message
how much was he asking for it?
pepsicola
Re: Quick question: ZE block with GE head? Mon, 07 October 2002 11:14 Go to previous messageGo to next message
700 bucks. he said the head as been clean up.
Grega
melbourne.victoria.austra...
Re: Quick question: ZE block with GE head? Mon, 07 October 2002 20:17 Go to previous messageGo to next message
if you want to build an NA motor get a 20v block/crank/pistons.
Re: Quick question: ZE block with GE head? Tue, 08 October 2002 01:41 Go to previous messageGo to next message
Yeah, 20v bottom end, with big port head, big arse cams and quad throttles. Bit of a pig maybe, but she'll sing when the revs are on. Oh yeah, speaking of revs, 11,000rpm and standard rod bolts don't mix Shocked I found that out the hard way...
pepsicola
Re: Quick question: ZE block with GE head? Wed, 09 October 2002 15:00 Go to previous messageGo to next message
um...the guy tell me that it retains the compression as it uses the ge pistons.
so any more comments??
pepsicola
Re: Quick question: ZE block with GE head? Thu, 10 October 2002 22:40 Go to previous messageGo to next message
any idea?
should i buy it?
kingmick
Banned by his request
moved to tamworth
Re: Quick question: ZE block with GE head? Fri, 11 October 2002 11:42 Go to previous messageGo to next message
hahahahahahahahahaha.
a gze with ge pistons is a 100kw ge that is all!
i think he might be feeding you a bit of BS. why would anyone go to the trouble of making a ze into a ge when a ge is alot cheaper. would mean they would have to have two motors to make one ge. dosnt make much sense? if you want me to explain futher just ask but you should get my drift!
mick
pepsicola
Re: Quick question: ZE block with GE head? Fri, 11 October 2002 12:55 Go to previous message
right. ic...
but the guy is too far away, he rather sell local.
bad luck.
Previous Topic:5spd internals
Next Topic:4agze power?
Current Time: Fri Nov 20 15:43:51 UTC 2026
Total time taken to generate the page: 0.084933996200562 seconds
