Toymods » Tech & Conversions » forcing turbocharger to boost higher
20vturbo
forcing turbocharger to boost higher Mon, 08 November 2004 00:37 Go to next message
hi guys, let's say we don't have the budget to get an external wastegate, would attaching a strong spring to the actuator wastegate be sufficient to hold the boost? i have seen with my own eyes a sr20det with large turbine, probably TD06 and i see a few springs around the actuaotr and the owner says's it's to hold the boost so it can go higher. someone says boost would not be stable if we keep this setup for a long time. what do you guys think?
AE86slut
Baulko Hillo
Re: forcing turbocharger to boost higher Mon, 08 November 2004 00:50 Go to previous messageGo to next message
A mate has done this on his 4AGTE..... Personally I think a bleed-valve would be the way to go for higher boost.
MR. 2
Parramatta
Re: forcing turbocharger to boost higher Mon, 08 November 2004 01:18 Go to previous messageGo to next message
well a larger spring is doing what the external does realesticlly, but be careful the internal gate is not ment to be pushed to extreams.
20vturbo
Re: forcing turbocharger to boost higher Mon, 08 November 2004 04:22 Go to previous messageGo to next message
yeah, some people says that aftermarket wastegate and the spring that he use is somewhat the same. just the one he use doesn't have housing.hemm...
AE86slut
Baulko Hillo
Re: forcing turbocharger to boost higher Mon, 08 November 2004 04:34 Go to previous messageGo to next message
MR. 2 wrote on Mon, 08 November 2004 12:18
I think he is talking about attaching a spring to the actuator to hold it closed against higher pressure.
ke382TG
Re: forcing turbocharger to boost higher Mon, 08 November 2004 05:11 Go to previous message
Depending upon your setup and how much "tension" is already applied to your wastegate actuator another two options are:
If your wastegate actuator is attached to your compressor housing and you have the ability to be able to "clock" the compressor housing in a direction which pulls the actuator further from the point at which it attaches to the wastegate flap this will add a small amount of extra tension. You would be surprised at the small amount that you move it is able to add more tension and gain more boost.
I ported my wastegate which in turn created a larger surface area trying to force the wastegate flap open. With the factory preload on the actuator it could not hold more than 12psi under load (you could bleed off enough for it to start at 20 psi but once loaded up it would drop to 12psi). So after carefully checking that the actuator had enough range of movement to still be able to open the wastegate flap sufficiently I clocked the turbo a little (adding more preload to the actuator spring). This allows me to hold a rock solid +20psi (no spikes, no creep, no drop).
The other method people use gives exactly the same effect as above but they cut the actuator rod and weld on a threaded section so that you increase the tension by shortening the actuator rod with the twist of a nut.
I have also seen the method mentioned above where an additional spring is added.
I would try a bleed valve first and use the above methods to correct any further problems (like I had with boost drop under load). As the above methods can be risky if you get a calculation wrong, ie limiting the wastegate movement, too much spring tension causing too much boost etc.
Think about what you are trying to achieve and then carefully go about doing it.
Previous Topic:3tgte ignition on 2tg?
Next Topic:$35 for a freekin thermostat WTF?
Current Time: Mon Oct 26 07:31:53 UTC 2026
Total time taken to generate the page: 0.027040004730225 seconds
