Toymods » Tech & Conversions » 18rgeu valves not opening fully
people100
Rocklea qld
18rgeu valves not opening fully Mon, 08 November 2004 08:45 Go to next message
ive been having dramas with my engine with valves. At first i thought it was valves hitting pistons but it turns out after removing the head again that the valves are not opening fully...when i turn the cam the valve open but not enough for the cam to fully rotate...what could cause this...the only thing i can think of is the collets are upside down but i thought they only went one way...what else can it be???
Re: 18rgeu valves not opening fully Mon, 08 November 2004 09:10 Go to previous messageGo to next message
stock cam?
higher lift?
springs binding?
wrong retainers?
collets in wrong?
wrong valve stem seals?
turn the cam slowly and see what gets close to what just before it stops moving.
good luck!
Jason
Re: 18rgeu valves not opening fully Tue, 09 November 2004 01:35 Go to previous messageGo to next message
Bent valves maybe?
Re: 18rgeu valves not opening fully Tue, 09 November 2004 03:11 Go to previous messageGo to next message
Jason wrote on Tue, 09 November 2004 12:35
Bent valves maybe?
was putting off mentioning this Wink
time to take off the springs and see if valves actually open at alll... Sad
Jason
Re: 18rgeu valves not opening fully Tue, 09 November 2004 03:41 Go to previous messageGo to next message
yeah well i cant really think of any other thing that it could be i mean 8 thou is only about 0.2mm which is fine and if People100 had other bent valves whats to say that he doesnt have more.
PS oldcorrolas check your PM's
Jason
people100
Rocklea qld
Re: 18rgeu valves not opening fully Thu, 11 November 2004 11:38 Go to previous messageGo to next message
turned out to be collets upside down solder pressure on the valve springs causing the valves to not have enough room to open fully.
Jason
Re: 18rgeu valves not opening fully Thu, 11 November 2004 21:54 Go to previous messageGo to next message
aha that'll do it every time Rolling Eyes
people100
Rocklea qld
Re: 18rgeu valves not opening fully Fri, 12 November 2004 09:43 Go to previous message
yeah it did it
Previous Topic:pipe fitting
Next Topic:1995 soarer 1jzgte pinout dash wiring diagram...
Current Time: Thu Nov 19 06:19:40 UTC 2026
Total time taken to generate the page: 0.0048270225524902 seconds
