Toymods » Tech & Conversions » 1g-gte Injectors
big JON
1g-gte Injectors Mon, 08 November 2004 08:47 Go to next message
At the moment im getting a new fuel pump...so i need some injectors to make a little bit of extra use to it...
Ive heard that 1jz injectors are a straight swap and are almost double the capacity of the standard ones...Is this true?
Cheers, Jon
Re: 1g-gte Injectors Mon, 08 November 2004 09:18 Go to previous messageGo to next message
i think 1JZ are side-fed injectors? if so, then 'no' is the answer.
even if they were physically fit-able, you'ld also have to deal with:
-the 1G injectors went from low to high impeidance at gen 2/3
-the stock computer will still think you have stock injectors and it's not reprogramable
it's your FPR that regulates how much pressure is in the fuel-rail - changing pump will do bugger all except keep fuel pressure up to the rail at all engine speeds (which the factory one did anyway).
if you want to make more use of your new fuel pump, get an aftermarket ECU and a risingrae regulator.
big JON
Re: 1g-gte Injectors Mon, 08 November 2004 10:03 Go to previous messageGo to next message
Ahh thanks. Its a little more complex then i thought Embarassed lol
So basically, in short, they wont be any good with either of the choices you've suggested below..? Just by changing the injectors i mean?
Jon
Re: 1g-gte Injectors Mon, 08 November 2004 10:54 Go to previous messageGo to next message
if you ran newer 1G injector (and the wiring/electrics suited) then a minor improvement - but you'd be running rich all the time (and most factory toyota turbos run rich for safety) - probably not worth it
i'd suggest external stuff like:
-boost controller (like one from celicamad)
-bigger exhaust
-bigger/better intercooler
-better air filter
-cold air induction
-if you can find them, newer gen 3 turbos?
big JON
Re: 1g-gte Injectors Mon, 08 November 2004 11:10 Go to previous messageGo to next message
At the moment ive got cat back exhaust, doing bugger all, custom pod/heat shield/cai and larger fuel pump (long story but getting installed as i had to drop the fuel tank for another problem anyway). On the cards is definitely bigger front mount, but i didnt really want to do a lot to this engine, as in a year or two it wont be there...and injectors were, i thought, a simple change...lol
Jon
Mookie
Tassie
Re: 1g-gte Injectors Tue, 09 November 2004 07:57 Go to previous messageGo to next message
I hear 7MGTE injectors are 440 cc and will go right in .
Correct me if i'm wrong as i've never tryed it i just read it on this forum
acmtt
Re: 1g-gte Injectors Sun, 14 November 2004 22:39 Go to previous messageGo to next message
Yes they will.440cc from 7m-gte, straight in to a gen 1 or 2.
They will overfuel with standard managment.
Been there!
speedvision
USA
Re: 1g-gte Injectors Mon, 15 November 2004 02:26 Go to previous messageGo to next message
hey mate if ur still interested in the 7mgte injectors 440cc i have a set for 200 aud .....regards
sam
dcving
newcastle nsw
Re: 1g-gte Injectors Mon, 15 November 2004 10:16 Go to previous message
13bt 550cc also slot, and plug straight in Cool
Previous Topic:TPS, but wrong connection? HELP!
Next Topic:celica engine swap
Current Time: Sat Nov 21 01:08:49 UTC 2026
Total time taken to generate the page: 0.0060257911682129 seconds
