Toymods » Tech & Conversions » erratic idle
greenta22
Dandenong Ranges, VIC
erratic idle Mon, 08 November 2004 08:59 Go to next message
my 2T is idleing kinda strange, it moves between ~600 and 1500rpm, even when warm. im pretty sure the mixture is fucked, but until i get my hands on a vacuum guage is there any way i can get this fairly right?
playing with the idle speed screw just makes the average speed slower or faster, it still rises and falls. it does have a lumpy cam, but it didnt used to do this. the PCV valve is connected, and assuming there aren't any air leaks, what else could it be?
thanks dudes.
b1gb3n
south Melbourne/KL
Re: erratic idle Tue, 09 November 2004 03:57 Go to previous messageGo to next message
same problem here. just that mine went to the extend where ingine died!! i have lumpy cams as well.
What i did is advanced ignition timing and increse idle screw. So instead of dying with idling around 500-1000, revs move at 1000-1400.
Not a solution, just damage control. Let me know what was wrong.
b1gb3n
south Melbourne/KL
Re: erratic idle Tue, 09 November 2004 03:58 Go to previous messageGo to next message
btw, my problem is suspected to be the shims. Urs might not have shims but it could be the valves not closing properly or something like that.
just an idea.
TA-022
Glenmore Park, NSW
Re: erratic idle Tue, 09 November 2004 10:13 Go to previous messageGo to next message
ive had the same problem here for the last 3 months.
just one day it started doing it... ive changed carby and manifold gaskets....all hoses nothing leaks.
i suspect burnt valve seat.
did comp test and all was fine so i dont think head gasket.
just cant justify spending money on that when i plan a 4age swap in the next 2-3 months.
i temp fixed mine like bigben sept its a biatch in the morning ... gotta keep the revs up for 5-10mins (read: no choke).
Hope this helps
Nathan
greenta22
Re: erratic idle Thu, 11 November 2004 08:17 Go to previous message
i raised the idle to about 1000rpm to keep it alive, then leaned out the mixture (it was mega rich), which brought the idle up to 1200rpm, then dropped it back to 600rpm, gave it a few more degrees of advance, and there she stays, burping away just between 500 and 700 rpm.
figure it was a combination of too much fuel and not enough idle speed.
Previous Topic:7M N/a boost noise?...
Next Topic:Sprinter boot lock loose
Current Time: Fri Nov 20 02:44:27 UTC 2026
Total time taken to generate the page: 0.0052750110626221 seconds
