Classifieds » Engines, Accessories and other Mechanicals » Altezza 3SGE/ IS200 6 speed gearbox for sale
panda_levin86
Altezza 3SGE/ IS200 6 speed gearbox for sale Mon, 08 November 2004 12:19 Go to next message
Have a 6 speed gearbox off a Altezza 3SGE.
Possibly a close ratio set inside the box.
would fit behind a IS200 1GFE
Near new.
Same box as S15, S2000, RX-8.
3,000
CelicaRA45
nth ringwood, Victoria
Re: Altezza 3SGE/ IS200 6 speed gearbox for sale Wed, 10 November 2004 05:34 Go to previous messageGo to next message
your talking in riddles here its either a 3sge altezza box or a 1gfe gear box witch 1 is it S series or G series and is it a close ratio trd set or you dont know whats 1 st gear 3,8 or 3.1
panda_levin86
Re: Altezza 3SGE/ IS200 6 speed gearbox for sale Wed, 10 November 2004 07:05 Go to previous messageGo to next message
Then its definitely a 3SGE box.
Cos it came with the engine
so I guess I can't go wrong there.
I have to find out what gearset is inside.
KOFFEE-BLACK
Re: Altezza 3SGE/ IS200 6 speed gearbox for sale Thu, 11 November 2004 02:24 Go to previous messageGo to next message
They are essentially the same box, but different b housing.
crazyracer
Re: Altezza 3SGE/ IS200 6 speed gearbox for sale Thu, 11 November 2004 09:09 Go to previous messageGo to next message
Actually the whole front of the gearbox is different. These don't have the separate bellhousing. Its incorporated into the gearbox casing. So trying to find the bits to do a swap would be challenging.
I'm also not sure how similar these are to the S15 200SX boxes. The shgifter arrangement is totally different and I think the shift pattern is different too.
Might be worth the $3K if it does have the TRD close ratio set in it though. I would doubt it if its just come via an importer though.
crazyracer
Re: Altezza 3SGE/ IS200 6 speed gearbox for sale Mon, 15 November 2004 00:05 Go to previous message
Are you able to check what the ratios actually are in this box by counting the turns on the input and output shafts in each gear?
Previous Topic:new Fidanza adjustable cam gears 4AG
Next Topic:Wanted: 2t or 3t bottom end Or complete motor
Current Time: Sat Oct 17 22:33:22 UTC 2026
Total time taken to generate the page: 0.0074238777160645 seconds
