Toymods » Tech & Conversions » Solexes in summer
amwtoy
Solexes in summer Tue, 09 November 2004 09:33 Go to next message
For a couple weeks now my car has been "gurgling" and jumping around when i put the foot down and i need to feather the accelerator SO lightly just to get it rolling i can barely hill start any more. A while back over at http://forums.toymods.org.au/index.php?t=msg&t h=46332&start=0 Joe suggested advancing the timing a bit... But then tonight it's raining and a lot less hot and the car was pretty much fine. Is it possible that the heat/humidity affects the way the Solexes are running? Is there a "proper" solution besides advancing the timing? I don't wanna get stuck rolling backwards on a hill because the car won't move Sad
benno_from_brizvegas
(Bris) Vegas
Re: Solexes in summer Tue, 09 November 2004 09:38 Go to previous messageGo to next message
bit of a stretch, but my '58 beetle does exactly the same thing, has a solex also.
tune up and timing always helped, but never completely cured it.
cheers,
benno
SIKTA22
Re: Solexes in summer Tue, 09 November 2004 12:04 Go to previous messageGo to next message
the temperature plays a big part with the solexs, during the mornings i try and start my car up and it wont idle, i have to have my choke open for a while before i can even start touching the accelerator, because if i try to accelerate it just chokes and wants to die.. after about 5-10mins then i can start playing with the accelerator. my method works though, its enough to get the car running anyway. if you want man, bring it over to my place i can have a look at it for ya?
cheers.
Jonny2TG
Tasmania
Re: Solexes in summer Tue, 09 November 2004 13:49 Go to previous messageGo to next message
Solex Mikuni sidedrafts have no compensation for differences in temperature. As soon as the temperature changed, they are out of tune, (or more in tune, depending on the initial state). Currently, mine tend to go better with warmer weather, and run lean and fart around if its too cold.
If it gets worse in warm weather, maybe they are running too rich. Tell us your jet sizes and specs, and I maybe able to help.
amwtoy
Re: Solexes in summer Thu, 11 November 2004 09:33 Go to previous messageGo to next message
Thanks for the tips guys. So now i'm sitting here waiting to see if the theory was right, and it hasn't gotten warm again! Sheesh. Joe, might give you a PM once it gets warmer again... As for knowing jet sizes, that's way beyond my knowledge of engines Very Happy
Re: Solexes in summer Thu, 11 November 2004 10:20 Go to previous messageGo to next message
Sure there's a proper solution; EFI!
amwtoy
Re: Solexes in summer Wed, 15 December 2004 13:00 Go to previous messageGo to next message
mrshin wrote on Thu, 11 November 2004 20:20
True that. Still, i took it in to the mechanic this morning because the last few days of really bad heat/humidity in Brisbane was making it chug along like a Harley with no torque... Turns out 90% of the problem was the old coil. I guess the humidity was making spark go through the air to ground instead of to the plugs. It still has very minor gurgle in the heat, but it's sooooooo much better. Very Happy
7mgtema71
Re: Solexes in summer Thu, 16 December 2004 00:18 Go to previous messageGo to next message
What I'd do is buy a brand new dizzy cap and very good quality leads as it appears (as your mechanic discovered) that the spark may be shorting in the dizzy cap due to moisture or dirt build up.
With extra thick and better quality leads, a better coil or even a booster for the coil you'll soon see that the strong spark will not only a produce a smoother drive but a boost in the power and more money in the pocket from better fuel economy.
The best you can do is re-jet your solexs for your climate or buy an EFI manifold and a cheap computer for similar price.
...just my 2cents.
Good Luck!
jeffro RA28
Tamworth
Re: Solexes in summer Thu, 16 December 2004 07:40 Go to previous message
If i remember correctly, with my race mx bike,
Cold air(more air density)= air fuel mixture will be leaner. therefore bigger jets reqired.
Warm air(less air density)= a richer fuel mixture so smaller jets are reqired.
Dry air(more air density)= a leaner mixture, so bigger jets are reqired.
high altitude above 1500m(less air density)= a richer mixture, so smaller jets are reqired.
Although motocross bikes running premix fuel is much more precise and touchy then car engines, the same principles still apply
i hope this has helped a bit.
Regards Jeff
[Updated on: Thu, 16 December 2004 07:41]
Previous Topic:Will a ST184 handling pack (bushings & swaybars) fit an ST182?
Next Topic:KYB AGX
Current Time: Sat Oct 24 11:41:47 UTC 2026
Total time taken to generate the page: 0.0087368488311768 seconds
