Toymods » Tech & Conversions » Ke55 rear disc conversion...
cwhelan
Adelaide, Semaphore
icon5.gif  Ke55 rear disc conversion... Wed, 10 November 2004 00:55
I have done enough searching and got all the info needed on the front disc conversion, so won't be digging this up from the dead... thank gawd, But with a fair bit of searching, I have not seen anything come up on rear disc conversion specifically on the ke55. Confused I am asking this question assuming the front has already been upgraded xt130/pug, knowing that the front would have to be upgraded in the first instance. With an inboard brake bias setup, I believe the rear conversion would be a good option.
Next Question, and probably a silly one, as I haven't paid attention to the threads read on the front conversion, as to what size wheels am I limited to? Wanting to keep the rim diameter as small as possible, wide and low profile. I was contemplating 13x9 rear and 13x8 front, but thanks to advice of these forums, I have changed my mind on this. I would like to have the rims around the 6"-7" wide mark if possible. The car will have to be engineered anyhow as I am doing the 2tg swap.
Any advice on this would be good, Thanks.
Ciaran
Previous Topic:4age coolant drain plug? where
Next Topic:Stuffed wheel bearings?
Current Time: Fri Nov 20 07:32:39 UTC 2026
Total time taken to generate the page: 0.0039758682250977 seconds
